5.3L t-5
The transmisson has a 10 spline input shaft.
If I use this bellhousing what starter, clutch and flywheel do I use? gm or ford?
and what else do I need?
Andrew
QuickTime 6037 scattershield, good luck finding a used one. It's kind of pricey also
LS1 flywheel & pressure plate
2000+ Mustang clutch disc
LS7 pilot bearing
96-04 Ford Racing clutch fork
Aftermarket clutch quadrant & firewall adjust of choice
Make sure you have the pivot ball in the bellhousing adjusted properly the first time or you'll be pulling the trans again.
BTW, how do you fit a ford input shaft into the LS7 pilot bearing?
LS7 pilot bearing
As for the LS7 pilot bearing fitting the Ford input shaft, I tested it to my input shaft while the trans was out. Fit just fine
