Quetion on Range Switch / Neutral Safety Switch
I am finally having my car wired and the guy doing the wiring isn't sure about what to do about a Range Switch. I have a 4L60e from a 2000 Camaro, mated to a 5.3 from a 2002 Yukon. I also have an aftermarket shifter from B&M, which comes with a Neutral Safety switch of its own.
My question is, do I need a stock Range Switch, or does the Neutral Safety switch that came with the shifter pretty much replace it?
I always try to run the range switch if possible or at the very least convert it to run the f-body style Park/Neutral switch. The LS PCM has 4 main spark timing tables (and what seems like a billion timing correction tables) and depending on if it is in gear or park/neutral it will use different timing tables. If you eliminate the range / neutral switch it won`t be able to switch between the p/n timing tables and may not run as efficiently.
Anyone else care to weigh in?
