Holley lsx oil pan?
What's with the windage tray that it comes with? Do I use stock one with f body pan or use after market it comes with?
If you only have 3/4 of the lower end/rotating covered, you would lose 25% of the effect of the windage tray and what it is designed to do. Most likely you would not even feel anything unless you were turning 7 or 8000+ rpm's. If at all.
For most, IMO, it wouldn't make any different. Just nice to have.
BC
The main studs should have threaded end on the studs that the Tray attaches to, GM uses self locking nuts.. But you could use locktight and/or lock washer is you using standard (metric) nuts.
BC
