Accessory brackets help
Old Apr 8, 2013 | 07:52 PM
duggravs's Avatar
Originally Posted by fox12303
Truck thermostat is fine with the Camaro LS1 pump.
Perfect. I'll save some money. And use my truck thermostat.
Old Jan 6, 2015 | 10:56 AM
MotorCityImpala's Avatar
Default A/C Bracket
I am interested in your A/C bracket. Do you still have the dimensions handy? What version of the SD7 did you use? Did you have any extra brackets made?
Here's a shortcut to the Holley bracket thread. The brackets are nice and fitup is good but it cantilevers the accessory outboard, it doesn't keep them tucked. It would eliminate any steering box issues though.
https://ls1tech.com/forums/conversio...c-bracket.html
Here's my LS1 hybrid drive with an SD7 compressor.
https://ls1tech.com/forums/attachmen...ccessory-d.jpg
And I believe sparkwirez06 is correct about the LS3 intake. You should look for an LS2 intake. There are alot of newer take offs for sale and aftermarket has cable throttlebodies.
Old Jan 6, 2015 | 11:08 AM
ShortyFON's Avatar
Im thinking about using this setup on mine
http://www.ebay.com/itm/5-3L-LS-Alternator-Power-Steering-Pump-Mount-Bracket-LSX-LS1-551570-/141504380552?pt=Motors_Car_Truck_Parts_Accessories&hash=item20f2517e88&vxp=mtr
Old Apr 10, 2018 | 10:11 PM
zeeks's Avatar
Default your hybrid bracket looks great.
Could you share the dimensions of the bracket and which AC pump and drive belt used?
