jgc steering box 1972 chenille
Old Apr 10, 2013 | 02:01 PM
dropped72ss's Avatar
Default jgc steering box 1972 chenille
I swapped a jgc box into my 72 chevelle and trying to find what hoses to use to connect to the ls2 pump from a tb ss? anyone done this swap have the part numbers i need?
Old Apr 10, 2013 | 02:31 PM
garys 68's Avatar
Isn't the TBSS accessory drive pretty much the same as truck?
If so 85 Monte Carlo hose, Jeep box, 5.3 truck PS pump in 72 olds with 1" setback plates. Be sure to use the lower return port if you have 2.
Old Apr 10, 2013 | 06:35 PM
did you just use a length of rubber hose with hose clamps for the return????^^^^^
Old Apr 11, 2013 | 01:27 AM
garys 68's Avatar
Yep, low pressure on the return.
