54 Belair LS swap
Are you using the stock front end? I have switched mine to a No Limit Engineering unit.
Are you using an aftermarket transmission crossmember for your car?
What motor mounts are you using? Could you take a picture of a front view of the mounts. Id like to see how high the bolt thru hole is relative to the frame rails
