My 1963 Ford Econoline 4.8/6L80E build
Old 04-13-2013, 08:03 AM
trozfan's Avatar
Default My 1963 Ford Econoline 4.8/6L80E build
I figure it's time to start a build thread for my Econoline Hippie Van.
I am 2 years in and still a very long way to go, but any progress is good right?
Here is what I started with:
After blasting:
And epoxy primer:
The following users liked this post:
Forcefed86 (01-19-2021)
Popular Reply
04-10-2021, 05:31 PM
trozfan
trozfan's Avatar
Well, here it is- after 10+ years and more money than I’ll admit to, the Hip-E-Van had its first ride today.
trozfan's Avatar
Next I bought a 4.8 and 6L90E off Ebay. It came out of a 2010 Chevy Express Van. The package only had 468 miles on it!!
Old 04-13-2013, 08:11 AM
trozfan's Avatar
Now on to the real thing. This was quite a task getting the engine installed. Lucky I had access to a lift or I couldn't have done it. The original engines are removed/installed through the side door, but I couldn't lift the engine high enough to get it in the doorway without the arm of the hoist hitting the top of the door opening. So it went in from the bottom on the stand, then lowered the van onto it. Then rolled the stand forward over the engine mounts.
Old 04-13-2013, 09:00 AM
trozfan's Avatar
Now onto the wiring. I am using the factory BCM; gauges; tap up/tap down shifting; criuse control; etc. I got the dash harness from a salvage yard, the BCM off Ebay, and the column/wheel off Ebay. As you can see the column/wheel is not from the Express Van. It is from a Malibu, I wanted a smaller diameter wheel and this one just looks cooler than the van one. Another reason I wanted a Malibu wheel is for the tap up/tap down shifting for the 6L80E. Yes, the Express van has tap up/tap down but it's a little rocker switch on the end of the column shifter! Not very cool or user friendly. So the Malibu has nice paddle shifters that I will have to re-wire to the resistors that match the express van values.
Gauges are working. There are 2 items that stay lit and show up in the Drivers Information Center- Air bag, and Tire pressure warning. I have read that these can be deleted from the BCM? But I don't do any programming so we will have to see on that. Now I can just remove the l.e.d. for them in the gauges. That solves the lighted icon, but the text will still come up in the D.I.C. until you push one of the D.I.C. buttons to get it off that text and back to Odometer or whatever else you want to see.
Econoline LS factory gauges, BCM<br/>1961 1962 1963 1964 1965 1966 1967
Old 04-13-2013, 09:20 AM
trozfan's Avatar
Rear framework:
I did a rear axle flip, so I have to make some suspension travel space. As the axle is now sitting on the frame. I cut out the entire rear floor to make the rear frame notch and structure for the gas tank and rear seat platform.
I bought a rear frame 'hump' from Alston and then modified it. I cut the bottom of each end off, and flipped them around and welded them in front and back of the hump to give it about 5 inches on each end that was parralel with the frame. The frame on the Econoline is tapered on both sides- wider on top than the bottom. So I added sides out of 4"x 1/8" plate steel to it that allowed me to slide it into the factory frame and weld my new tapered sides to the original frame.
Here is the finished rear frame/gas tank/seat platform structure:
The tank is from Tanks Inc. and is for a 1953-1954 Chevy. It is a fuel injection tank so it has the sump in the bottom of it.
Old 04-13-2013, 10:14 AM
tired2valve's Avatar
This is badass.
Old 04-13-2013, 10:27 AM
Project GatTagO's Avatar
Received 1,441 Likes on 909 Posts
Originally Posted by tired2valve
This is badass.
+1
Andrew
Old 04-13-2013, 10:34 AM
chromeplated500's Avatar
subscribed, I do believe the power and reliability of the 4.8L are overlooked!
if you don't mind posting, what did the engine/trans/harness/speedo ect cost ya?
Old 04-13-2013, 12:06 PM
trozfan's Avatar
Engine/trans/harness was $2,750 shipped. Speedo was $60; dash harness was $150; BCM was $75
Old 04-13-2013, 12:19 PM
trozfan's Avatar
Here is what the exterior looks like right now. The front will be MUCH lower. I still haven't decided if I am going to do a dropped axle or a Mustang II clip. 90% sure I am doing Mustang II. The original suspension/steering/brakes on this thing is a joke and I am going to be driving the heck out of this thing so it's got to be safe and reliable.It's got Boss 20" on back and 18" on front. Doing hidden hinges on all 6 doors (yuck!, tons of work). Has late model Corvette door handles on front where you reach around and push the sensor pad. I have notched the body similar to the Corvette so you can fit your hand in there.
1963 Econoline <br/>1962 1962 1964 1965 1966 1967
Old 04-13-2013, 12:22 PM
trozfan's Avatar
Front body mods:
Here is a shot of my planned front body mods. The grilles on these are ugly and the parking light corners don't thrill me either.
- Narrow the grille opening about 4 inches on both sides and round the corners.
- Cut out an air dam under the grille
- New parking light corners
- Small split bumpers at the corners
Old 04-13-2013, 08:18 PM
SatisTraction's Avatar
lots of custom work going on here!!
Old 04-13-2013, 08:34 PM
MYSTIC-1SC's Avatar
Very cool build, looking forward to more progress pics.
Old 04-13-2013, 09:27 PM
stangtrader's Avatar
Awesome build man,looking forward to the progress
Old 04-14-2013, 01:09 PM
ls1nova71's Avatar
This thing is killer! Nice work so far, especially on those hinges. I wasn't sure you were going to be able to pull it off with that much curve in the front jamb, but looks like you got it. Keep up the good work, I'll be following along.
Old 04-14-2013, 03:29 PM
350SS's Avatar
you're my hero
Old 04-14-2013, 06:03 PM
nos487's Avatar
Awesome build! glad to see something totally different.
Old 04-16-2013, 03:11 PM
trozfan's Avatar
Anyone that is doing all the wiring for not only the ECM/TCM, but also the BCM; gauges; steering wheel controls; paddle shifter; etc. knows how handy the original diagrams are! Best money spent- alldatadiy
Old 04-16-2013, 08:26 PM
claybob's Avatar
All I can say is WOW! Wish they made LS motors in the early 80s when I had my 64'. True babe magnet.
Old 04-16-2013, 08:30 PM
DEEDDUDE's Avatar
Great work. Can't wait to see it completed. I always wanted to drop one of these in the weeds with some 70's slot mags and white lettered tires.
Quick Reply: My 1963 Ford Econoline 4.8/6L80E build
