OBD II scanner
Old Apr 15, 2013 | 07:57 PM
flynbrian48's Avatar
Default OBD II scanner
So, thinking that I have 4 hot rods with computer controlled engines, no way to scan 'em at home a diagnose any problems, and with some frustrating trouble with the 6.0 in the Diamond T, I'm going to buy a scanner. I see Auto-Zone has 'em from $59.00 up. Will the inexpensive ones be adequate? Any recommendations for an inexpensive one that would help me out? Not interested in reprogramming, just trying to dx problems as they arise.
Brian
Old Apr 15, 2013 | 09:45 PM
71403's Avatar
There are several PC based packages that fit financially between hand held cheapies and $$$ scan/tune tools. The first time to you need to record data to find a driveablity problem you'll be glad you did. Also lets you keep your eyes on the road.
Don't want to name names since no idea if any are sponsors here. PM if you need to.
Old Apr 15, 2013 | 09:48 PM
ZQV8's Avatar
I have a pocket style scanner that matco makes, think it was $150
Reads/clears codes but it also reads over 100 data parameters. I've had a couple cheap scanners that just read/clears codes, sold all of them and won't go back.
I use it on a daily basis at work and it does a great job.
http://www.matcotools.com/catalog/pr...CAN-SCAN-TOOL/
Old Apr 15, 2013 | 09:57 PM
bczee's Avatar
If you have and Andriod Smartphone or tablet.. load up "Torque".. and buy a BlueTooth Wireless ODBII connector (Ebay $25.00)..
I use it to monitor, clear code and it has a host load of fun stuff.. (but it can't do programing..), Laprecorder, map/gps, configurable screen. etc..
http://torque-bhp.com/
BC
Old Apr 16, 2013 | 12:59 AM
roninsonic's Avatar
+1 on Torque... I have Torque PRO, and it's AWESOME. You can datalog, do custom PIID's... It's boss... And less than 50 bucks for Torque PRO and a bluetooth adapter, PLUS a windshield mount.
You can also put some film on the windshield and Torque has a HUD mode.
Old Apr 16, 2013 | 02:20 AM
BOXCHEV's Avatar
I use a harborfreigt one, the one that's usually $120 or so. I got it on sale for around $70 with a coupon. It's used mainly for the daily drivers. Got tired of running the car down to the shop for a $10 read. It does okay for basic problems.
I'd shoot for the slightly higher dollar ones that have more options or some good software to use with a lapt top or something when troubleshooting with a swap. Good scanner/software and digi multimeter should get things done.
Old Apr 16, 2013 | 02:38 AM
SMKE EM's Avatar
I bought the OBDLink SX, for $40, it connects from the OBD2 port to a usb port on a netbook. I use it for everything, the only thing it can't do is program.
Old Apr 16, 2013 | 06:43 AM
Pop N Wood's Avatar
I have a harbor freight one that I got on sale for something like $25. It is an older model that was only $40 new. I keep it in the door pocket for when buds at work need to clear or read a code. Doesn't data log and only displays the code number so you still need to google what the number means, but for the money it is hard to beat. Throw one in every tool box.
BTW, most part stores will read error codes for free.
Can't say I've ever had a problem that needed data logging. That smart phone solution sounds trick. My wideband does OBDII logging but luckily I have never needed to use it.
Old Apr 16, 2013 | 07:29 AM
garys 68's Avatar
I've got a cheap harbor freight too. Works fine for simple codes. I did end up spening about the same for an Elmscan that additionally displays sensor data on my computer. That's very helpful with diagnosing initial issues with swaps.
Old Apr 16, 2013 | 07:45 AM
1964SS's Avatar
I use the ELM bluetooth obdII connector and my smartphone with Torque Pro loaded on it. Does more then any cheap scanner and costs less.
Old Apr 16, 2013 | 12:40 PM
Thanks for the replies. I don't have a smart phone, (I'm holding out) so that's out. I'm thinking a cheap scanner will have more than I can figure out how to use, so that will probably suffice. I still think I have a fuel delivery problem, so that's the first thing to get straightened out, but a scanner will be nice to have as well.
Old Apr 16, 2013 | 02:04 PM
jtotheizzo's Avatar
Would just get an elm usb cable and there are plenty of free programs out there for this. If you have a laptop it is pretty much the cheapest option. Then you can upgrade software later if you so chose.
Old Apr 16, 2013 | 02:32 PM
badazzt/a's Avatar
Torque pro is definetly the way to go think the app is like 4.99 and u can get a bluetooth connector for around $20 on amazon
Old Apr 16, 2013 | 03:56 PM
usdmholden's Avatar
I have an Innova I bought a few years ago off Amazon, I bought a more expensive model because it would also go antilock brakes, and I needed it. It works good, never really had a need for the USB laptop setups but I do think they have some nice features.
Old Apr 16, 2013 | 07:57 PM
i r teh noobz's Avatar
I have that same scanner. Works great for home use, very simple and fast for most cars. Supports enough live data to do minor diagnostic checks as well.
Actron makes it for Matco. Advance Auto carries the Actron version for around 120. If you have a little extra, the same scanner with domestic ABS is around 200.
Old Apr 17, 2013 | 08:51 PM
bonecrrusher's Avatar
+1 on the Torque app and bluetooth combination - I use it to datalog when I do my 1/4mile and autocross runs.
Old Oct 27, 2014 | 02:19 PM
Huggybear19K's Avatar
Which app/Bluetooth scanner yall recommend for iPhone5
Old Oct 27, 2014 | 06:14 PM
roninsonic's Avatar
Who still uses Iphone? ANDROID FOR LIFE!
Old Oct 28, 2014 | 11:37 PM
bczee's Avatar
suggest you search in the iPhone play/app store. Search on ODB2 or ODBII scanner. There was a few the last time I played on someone iPhone... most have a charge for installing.
let us know your review of what you find.
BC
