LT1 to LS1 engine harness.
Old Apr 17, 2013 | 09:03 PM
SINISTER-TA's Avatar
Default LT1 to LS1 engine harness.
Looking for some guidance on what would be the best place to send my LT1 F-body harness to get converted to an LS1 F-body harness.
I'm doing an LS swap into my 94 Z and trying to make it as painless as possible.
Thanks.
Old Apr 17, 2013 | 09:52 PM
BP Automotive's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
We can convert it, or build you a brand new plug and play harness with the factory firewall grommet. We specialize in harnesses for 4th gen fbodies.
Bill
Old Apr 18, 2013 | 09:42 PM
Bill
Sounds great! Can you give me contact info?
Old Apr 18, 2013 | 10:12 PM
LS1Tech Sponsor
Sure. Its on our website, but you can call us at
270-805-1777
Old Apr 19, 2013 | 12:46 PM
Strokinit383's Avatar
Just do it yourself, it really isnt very difficult. There are a ton of good wiring resources on this site.
Old Apr 19, 2013 | 05:00 PM
I have read a few of the write up's, however I'm still a little uncomfortable trying this on my own.
Old Apr 21, 2013 | 01:12 AM
the_merv's Avatar
Veteran: Air Force
Wire is just a wire..it carry's a signal..
Old Apr 24, 2013 | 08:56 PM
Thanks for the inspiration merv! I have read one of your write ups. You seem very knowledgeable in wiring, and any advice you want to throw my way is greatly appreciated.
Old Apr 24, 2013 | 10:41 PM
the_merv's Avatar
Veteran: Air Force
I have the knowledge and experience..is really is that simple.
What do you want to know?
Old Apr 25, 2013 | 10:39 AM
Do I need a complete LS1 harness to merge with the LT1 harness? If so does it matter if it is a m6 or a4 harness?
Old Apr 25, 2013 | 11:51 AM
the_merv's Avatar
Veteran: Air Force
What are you building?
There is only one connector that needs to be switched over from the LT1 Engine Harness onto the LS1 Fbody Harness..so I would go to the Junkyard and clip that connector from a V6 mid 90's Fbody and integrate it onto the LS1 Harness, and then you can sell your LT1 Harness.
Old Apr 26, 2013 | 12:06 PM
I have a 94 Z28 that I'm swapping in a LQ9.
I didn't think it would be that simple. What connector would that be?
Old Apr 26, 2013 | 12:37 PM
the_merv's Avatar
Veteran: Air Force
Black one under the Dash on the inside of the car..C210. It has the big purple wire in it.
Old Apr 26, 2013 | 05:04 PM
Okay...just to be clear if I use an LS1 F-body harness than I only need to change that one connector (C210)? And I'm assuming that I would need an A4 harness if I want to use my original 4L60E?
Old Apr 26, 2013 | 07:27 PM
LS1Tech Sponsor
You need to change much more than just one connector....
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old Apr 26, 2013 | 07:30 PM
black and pink z28's Avatar
I just had bill at bP Automotive do my harness for me i will have mine back tomorrow
Old Apr 26, 2013 | 08:27 PM
How much did it cost?
Old Apr 26, 2013 | 08:31 PM
Yeah...that's what I figured. I need to give you guys a call soon.
Old Apr 26, 2013 | 10:20 PM
the_merv's Avatar
Veteran: Air Force
You integrate that connector, aswell as change the placement of wires on the existing connectors that are there.
I've been busy working all day so to judge what I've posted without giving me a chance to explain is it going a little far..lol..
All I have is quite a few functioning harnesses in builds of my own aswell as others..so I must be doing something right.
Old Apr 27, 2013 | 12:27 AM
armyinfantry3id's Avatar
LISTEN to MERV, i followed his threads on the wiring conversion, it is very easy. i did my own and would not hesitate to do it again, plus you get a great feeling of knowing YOU DID IT. Trust me when i say you will be happier with the end result!
