Power steering pumps ls1
Old Apr 21, 2013 | 10:22 AM
camaromotorsports's Avatar
Default Power steering pumps ls1
Heads up on pumps , you can use a 3.8 v6 pump off 96-02 fbodies on the ls conversions , they have a remote resivor and a steel pulley , we have had aot of customers use them on their swaps , thought the info might be helpful
Old Apr 21, 2013 | 01:22 PM
bczee's Avatar
Do you ave any pictures of the install with the remote ??
thanks for he info... I have been considerin doing a remote one..
BC
Old Apr 22, 2013 | 03:17 PM
sorry , i do not , I have just sold several to customers and they have a bracket that can be used , all you need is a flat space , i will try to post a pic of the setup next few day
Old Apr 23, 2013 | 01:56 PM
Bilster's Avatar
Good information!!
Old Apr 25, 2013 | 10:14 PM
lownslo64's Avatar
Ever heard of intermittent power steering issues with LS1 pumps. My steering cuts out randomly and most of the time it doesn't work. I'm thinking pressure relief spring sticking... Car is a 64 impala with LS1/4l60e has a Delphi 600 steering box with stock LS1 pump..
Any help is appreciated
Old Apr 25, 2013 | 11:09 PM
bczee's Avatar
Is it like locking up under throttle ? I got them on my Chevelle for a while. I added a cooler to the return line (from a 02 Z28) and that resolved it.. The newer Pump have a higher pressure rating as compared to the old pump and box.. excessive pressure might be causing the Heat.
you might try adding a cooler or adjusting the Relief valve/spring.
BC
Old Apr 26, 2013 | 12:05 AM
sal0327's Avatar
Do you use the stock 3.8l bracket?
Old Apr 26, 2013 | 04:31 AM
evldoer's Avatar
I dont think the bracket from a 3.8 would work, but a 5.7 bracket does. I got an aftermarket bracket from ebay for the f body acc. drives. I used a 3.8 pump, made a resivoir that sits on top of the pump. Right now the tank is at the anodizer, but I will post another pic when I get it back. Here is a pic without the tank.
Old Apr 26, 2013 | 05:17 AM
Fierofly's Avatar
A totally different option is to use a remote mounted Toyota MR2 Electric Pump/Res.
Old Apr 26, 2013 | 07:28 AM
gofastwclass's Avatar
Attachment 400422
Could you post a little smaller picture, I can ALMOST see what it looks like.
Got any information on what year(s) to use and what the pressure rating is? Is it a simple two wire hook up or is it more complicated? Are they expensive? Are they reliable (I don't follow Toyota stuff)? ...and finally, how big is it?
Old Apr 26, 2013 | 09:23 AM
bczee's Avatar
Found this thread on using the MR2 pump..
https://ls1tech.com/forums/suspensio...on-w-pics.html
BC
Old Apr 26, 2013 | 11:27 AM
ls1nova71's Avatar
This is interesting, but does the pump run the whole time the key is on? Or is there some kind of sensor that's supposed to be on the column to turn it on when the wheel is turned so much?
Old Apr 26, 2013 | 05:55 PM
Fierofly's Avatar
This is the Power Steering pump Kit I bought from Renegade Hybrids for my Porsche 996 LS3. Will be installing SOON.
Old Apr 28, 2013 | 05:49 PM
Fierofly's Avatar
Started power steering pump install in my 2003 Porsche 996 LS3 install last night
Old Jan 16, 2014 | 09:20 AM
ahhwataday's Avatar
Im gonna try the v6 pump within a few weeks. Ill try to get pics
Old Feb 11, 2014 | 07:16 PM
alltheoctanes's Avatar
For you guys that have done the 3.8 pump on the LS, does the pulley line up with the serpentine system well?
Old Feb 13, 2014 | 12:42 PM
Litoflow's Avatar
That electric power steering looks really good. @Fierofly
Old Feb 14, 2014 | 10:21 AM
Pocket's Avatar
You can use just about any pump you want. Im using a northstar PS pump/res and S10 alt with my Techco build
The smaller shaft pumps like Fbodys use are almost 100% interchangeable. Common differences are the nipple pressed in for a remote res, and hole type. Threaded vs through
Old Mar 8, 2014 | 12:19 PM
WCRiot's Avatar
So what was the final outcome of this info? I need a power steering pump for my Ls1 swap. the v6 pump is much cheaper and easier to find.
