has anyone done an ls1 in a dodge magnum wagon
Old 08-02-2013, 09:33 AM
ASSuming On The Tree
audacious nick's Avatar
Originally Posted by s/clsxmagnum
all gauges except speedo work. I haven't spent much time with that one, It uses abs for a signal. It worked before I deleted abs. I will go aftermarket. I will fit them in the stock cluster.
also for nick.... my shitty wagon goes 10.46 at 128 on a low budget build and weighs only 100 more pounds than my friends 2ss. and can seat 5! When you have kids this becomes important.
Cool, so it weighs 100lbs more than an already-heavy 2ss? I'm so proud of you.
It's not like a g8 gt would weigh less and already has the proper stuff, not to mention the higher quality. Or would it?
Old 08-02-2013, 09:45 AM
ryeguy2006a's Avatar
This is just a pissing match. I say line up what you have and end the debate.
Old 08-02-2013, 09:50 AM
How would that end the debate? At the end of the day, a g8 is a far superior car in every way.
I do not own one anymore, so I couldn't line up. And lining anything else up would not prove anything.
Old 08-02-2013, 11:28 AM
Rick Speed's Avatar
Just curious since all the gauges have bussed messages how did you get them to work?
Old 08-02-2013, 12:28 PM
SWAGON's Avatar
+1 on LS BMW wagon. Although I might be biased
Old 08-03-2013, 07:38 PM
s/clsxmagnum's Avatar
I bought the car for $4000. I paid $400 for the drivetrain line and pcm wiring. spent $2500 on comp cam, springs, push rods, arp bolts, rocker arms, gaskets ect. built the supercharger kit myself. I paid $800 for those materials. $250 for tuning. $350 in exhaust. = $8,300 how much was that sweet g8... don't be a hater! A G8 GT is a sweet ride I would gladly trade.
Old 08-03-2013, 07:45 PM
tach doesn't work... 2.7 v6 vs 4cyl signal needed. The temp, gas gauge, and alt all work. The speedo worked until I deleted the abs. I will be going aftermarket soon as posted.
Old 08-03-2013, 08:35 PM
Default ls based magnum twins if one wasn't enough!
Short idle video. I am only running one currently... going turbo soon!
Old 08-30-2015, 11:34 AM
jeph210's Avatar
Default ls swap dodge magnum
Old 09-18-2018, 09:27 AM
Wracks71's Avatar
Does anybody know this guy,or shed any light on wiring? I am in the middle of doing a 5.3 in a magnum.
Quick Reply: has anyone done an ls1 in a dodge magnum wagon
