Fox guys..what did you do for drive shaft?
Old 04-23-2013, 01:51 PM
streetknight2's Avatar
Default Fox guys..what did you do for drive shaft?
Need to go from TH350 to 8.8 round yoke.
Old 04-23-2013, 03:29 PM
1bad03snake's Avatar
I got a yolk from a 4l60 and a pinion flange from.a stock ds. Houston drive line service put it all.together
Old 04-23-2013, 03:36 PM
MustangLS's Avatar
I had to have one custom made. It's about 48.5" or so (SN95 and Fox are the same) with a TH350 and 6" tailshaft housing but you need to measure to be sure.
Old 04-23-2013, 07:29 PM
topendrunner's Avatar
i had one made by a local shop. i didnt have anything so i measured from the rearend to the trans rear seal and they did the rest. cost 350
Old 04-23-2013, 07:46 PM
lebedin8654's Avatar
Yea your local drive line shop should be able to hook you up. You can reuse the flange off your fox driveshaft to save a few bucks
Old 04-23-2013, 09:23 PM
bad6as's Avatar
Called the drive shaft shop
Quick Reply: Fox guys..what did you do for drive shaft?
