Blue Monte Carlo 5.3 Swap
Old 09-06-2015, 10:39 PM
  #41
deuce4935's Avatar
What trans are you using?
Old 09-07-2015, 12:14 PM
  #42
GreazyDaMonsta's Avatar
200r4
Old 09-07-2015, 12:57 PM
  #43
The computer is out of a 2001 Silverado
Old 09-07-2015, 07:48 PM
  #44
N20zuki's Avatar
Originally Posted by GreazyDaMonsta
What about the vss. Does it need to be hooked up? May that he the cause of my problem? If so, what is the pin #? I have blazer converted front brakes.
The brakes have nothing to do with a VSS... The VSS is given from the trans... I have no idea what people use for VSS conversion with a SBC trans.
Old 09-07-2015, 09:15 PM
  #45
Old 09-09-2015, 06:50 AM
  #46
Why is it doing this
Old 09-09-2015, 07:54 AM
  #47
M6 Swap's Avatar
no oil to 1 head but oil to the other........
Old 09-09-2015, 01:06 PM
  #48
N20zuki's Avatar
Have you checked for codes yet?
Old 09-10-2015, 02:35 PM
  #49
Not throwing any codes
Old 11-15-2015, 04:05 PM
  #50
I found out what was going on. The fuel line had rusted out a was leaking gas.
Old 11-15-2015, 04:21 PM
  #51
Default baby burnout
Old 11-16-2015, 12:15 PM
  #52
L92 OLDS's Avatar
Sweet!...posi in the rear. While you're at it replace your brake lines too. My neck hurts from watching your first 2 vids.
Old 11-20-2015, 08:20 AM
  #53
Thanks I will. Right now I'm doing my blazer spindle conv. I'm having a problem where the flex line screws into the caliper fluid keeps flowing out no matter how tight I do it
Old 11-20-2015, 11:21 AM
  #54
Alwhite00's Avatar
Do you have new copper washers on the banjo fitting on the caliper?
Old 11-20-2015, 03:29 PM
  #55
No I didn't. I thought you could use the old ones
Old 11-22-2015, 09:47 PM
  #56
My buddy just got his hands on a 78km turbo. Does anyone have 80lb injectors
Old 11-23-2015, 11:11 PM
  #57
'87 Monte SS's Avatar
Looks like your havin' some fun! Whose Solar Gold Trans Am?
Old 11-24-2015, 08:58 AM
  #58
Mine I just bought it
Old 11-24-2015, 07:11 PM
  #59
I guess no one likes answering questions here
Old 11-25-2015, 04:58 AM
  #60
Alwhite00's Avatar
Maybe no one has 80 lb injectors. ????
Quick Reply: Blue Monte Carlo 5.3 Swap
