Which fuse panel to use from this LQ4 dropout?
So close to firing up my car! This is the only thing holding me back. Anyone have input?
https://ls1tech.com/forums/17353216-post200.html
I don't think Brendan says you NEED to use that fuseblock......I have seen a page on there about how to RE USE that fuseblock. He has a few other pages on there about using just a small 4 fuse holder as well......much simpler to do. Unless you are REALLY set on using that gigantic fuseblock. I am going to use a newer Caprice/Impala SS holder, because on my 85 with the LT1, it fits very well.
Do you WANT to reuse that huge thing?
I had origianlly used the F-Body Fuse box on my Nova project.. but it was just a pain to mount and fit it where it would look good.. so I dump it..
But I had completely stripped it and re-wired it. It is not hard to do, but it would make it easier if you bought some new terminal and connectors and the crimper. Also just get the pin tool to remove the terminal from the fuse box.. most auto parts place have them.
If the box has more than you need, got to the JY and find a smaller one. I am sure they are cheap.
BC
BC
