5.3 Vortec- Temp Sensor Wire Cut Off by Accident - HELP!
Okay, I'm the careless idiot who accidentally cut off my temperature sensor wire while "editing" my wire harness for my engine swap. Now I get to try to fix it. The problem is that I cannot find the sensor or the wires needed to power the sensor. Can you guys help figure this out?
LS1Tech Sponsor
The CTS circuit is as follows.
Connector
Cavity A-Black. Goes to Blue 80 at the PCM
Cavity B-Yellow. Goes to Blue 74 at the PCM
Bill
Connector
Bill
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic241851_3.gif)
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
Okay, and thank you for the quick response. But, I threw the connector in the trash so I need to find a replacement. Since I don't have the old one to look at I need to know which wire goes to which pin.
