reversing the Intake Manifold?
Old Apr 24, 2004 | 05:38 PM
Classic Style's Avatar
Default reversing the Intake Manifold?
Ok, while trying to make my LS1 fit in the 911, I have come to a new problem. The intake manifold needs to be reversed.
What is required to make this happen?
Do I have to swap the heads as well?
What do I do with the oil pressure sensorand CMP sensor at the back of the block?
I also need to know if there is a special order for undoing the bolts on the intake manifold?
Thanks
Old Apr 24, 2004 | 07:22 PM
felton316's Avatar
I have seen it done on this board before, but I do not remember who did it. The only trick piece that was used was a 90* fitting for the oil pressure sensor. You do not need to switch the heads around.
Old Apr 25, 2004 | 12:53 AM
Cheatin' Chad's Avatar
https://ls1tech.com/forums/forumdisplay.php?f=28
Check the hybrid section this comes up all the time.
