Crankshaft spacer question
If there is no room, you probably didn't seat the converter in the transmission properly. Loosen the bolts on the transmission and slide it back until the converter spins by hand. Rotate the converter by hand and push it toward the back of the transmission (in) until it seats all the way in. If you keep trying to force it together you will damage the front pump on the transmission.
The 5.3 will not have a spacer from the factory as only 6.0 engines came with 4L80E transmissions and required them. The only way that engine would have a spacer or flat flexplate is if someone added it.
Used to work on the fragile ZF transmissions found in Audis and BMWs, so I hope I know the deal..
I was just wondering... Maybe the Express with AWD, which this engine comes from, used the 4L80E on the 5.3 as well?
I'm going to pull the transmission anyway to take a look at the flexplate. Don't have any pictures available, but stay tuned!
