Difference between Corvette, Camaro, and Truck Accessory drives
I searched everywhere on here, to find how much further out the F-body accessory drive are spaced out from the Corvette drive. After about an hour of reading I saw a post that said about 5/8 inch. I ordered the closest pulley for the waterpump and a Camaro balancer, that along with a 1/8 spacer under the waterpump pulley should be perfect according measurements. Well the difference is 3/4 inch NOT 5/8, looks like a trip to the machine shop is due.
So no one else has to go thru this here is the height measurements and Pics.
Corvette- 2-27/32 in.
F-Body - 3-21/32 in.= + 3/4 over Corvette
Truck - 4-3/8 in. = + 23/32 over F-body or +1-15/32 over Corvette
The following users liked this post:
V8e36 (09-28-2020)
If you would refer to the chart from Holley above, it shows the G8 to be "standard", or Corvette, and the Chevy SS, being based off the Vette, would also "standard"
Standard is the tightest fitment to the front of the engine.
