How to Wire Up a Starter on LS Swap???
Old May 18, 2021 | 07:21 AM
ls1nova71's Avatar
Originally Posted by VAGOS MTB
my stand alone harness has a thick purple wire and a small wire for starter+ And i have one for the battery to the starter we’re do I hook up the thick purple wire from the harness can someone help is a 89 obs
If your stand alone harness has the starter wire in it, it probably won't be hooked to anything on either end, because one end goes to the ignition switch and the other goes to the starter solenoid. What harness is it? Does it have a starter relay/neutral safety switch built into it?
