4 wheel drive conversion?
I did a awd 240sx but it didn't turn out good. Not enough hood height made for poor front cv shaft angles. (in hind sight I should have mounted the engine higher and ran a higher hood or poked the intake through the hood like alot of the c6 vettes are doing now. I parted it out, but I still have most of the parts. If you look on the syty forums you can find the adapters for 4l80e to syty t case. If you go that rout the case internals can be modded so that it acts more like 993 turbo awd. ( the front diff would be viscous coupled rather than having a viscous diff between the two, if you don't follow what I saying I can explain further)
