-another- Speed Inc. TT Typhoon build
Since Dan Marks (lead tech/fabricator here) had already built himself a twin turbo LS1 powered Typhoon that consistently runs 9's on pump fuel, it wasn't hard to show him the advantages of switching to LS power.
Going into the truck is a 427ci LSX shortblock built by Texas Speed. 226/230 115lsa comp hyd roller cam, TFS 245 heads and an LS2 intake manifold.
Exhaust is dual 3 inch downpipes going into a Magnaflow muffler with dual 3in inlets and a single 3.5in outlet.
Trans is a customer supplied Rossler 4L80E.
Rearend is a Strange 12-bolt with a tru-trac diff.
The stock front torsion bars and control arms were replaced with a coil over setup from RPM.
Turbo system consists of flipped/modded 2010 Camaro manifolds, Precision 6262 Ball bearing turbos, Precision wastegates and 2 Precision 500hp air/water intercoolers.
Fuel system is twin in-tank walbros, stock fuel lines, 80lb injectors and will be ran with a stock PCM and HP Tuners 3bar speed density operating system.
and as cool as the V6's in these are you can argue with the reliabilty of the LS platform for making power,I have over 15k and at least 25 mid 9sec passes on mine and have only changed the oil regularly and spark plugs one time,I would like to see a V6 truck make the same claims doesnt take anything more than a imput shaft upgrade to allow for the 4L80 adaption,mine has held up great,including a few 1.3 60' times
Hope this one turns out as good as the other one. I would really like to have that rear.
we will keep the updates coming as we progress
