-another- Speed Inc. TT Typhoon build
Old Feb 16, 2012 | 11:49 AM
boost27's Avatar
Amazing, how do the the 2010 camaro manifold clear the steering shaft? I just started up my typhoon with the ls swap for the first time last weekend. You have 2 under belt almost before i can can even get mine to run lol. AWESOME work!
Old Feb 16, 2012 | 12:00 PM
danimal95's Avatar
thanks,it took a bit of machining/welding and a RPM low profile steering shaft
Old Feb 16, 2012 | 12:06 PM
danimal95's Avatar
Originally Posted by ramairetransam
sweet , kinda wish it stayed with the 6 but , and when can you turbo a smart car or prius .
huh?????not only can it be done but there are bolt on kits available
Prius system
smart car system
Old Feb 16, 2012 | 02:52 PM
danimal95's Avatar
accessory drive Wegner Motorsports
Old Feb 16, 2012 | 07:36 PM
427's Avatar
427
We did 30 turbo installs on the Toyota Prius! That truck should be a blast.
Kurt
Old Feb 16, 2012 | 08:34 PM
onfire's Avatar
Coal Mining Director
Turbos on a Prius....sorta like **** on a boar hog......
Old Feb 16, 2012 | 08:39 PM
John Deere racer's Avatar
Top notch stuff as always Dan!!
Old Feb 18, 2012 | 03:04 PM
427's Avatar
427
Actually built one twin turbo (compound) Prius engine, that was different!
Kurt
Old Feb 18, 2012 | 08:53 PM
onfire's Avatar
You don't count...you'll make anything fast....
Old Feb 24, 2012 | 07:45 AM
a4ls2goat's Avatar
that is badass..
this thing should fly..
how did you guys go about welding the manifolds? isnt a special kind of weld needed so it wont break?
Old Feb 24, 2012 | 08:01 AM
lollygagger8's Avatar
This thing is gonna be a monster! Very cool!
What are turbo Prius's running in the 1/4? 16's? lolz
Old Feb 25, 2012 | 08:54 AM
  #32
sparkwirez06's Avatar
Is this 2.5" intake piping?
Old May 4, 2012 | 12:30 PM
  #33
boost27's Avatar
Any updates?
Old May 5, 2012 | 12:17 AM
  #34
91sonomast's Avatar
Every time I see a Sy/Ty getting a turbo LSx it gives me the itch. The more I think about it the more I look for a extended cab 4wd frame for my sonoma. As long as the T-case will hold it together this looks like LOADS of fun! AWD donuts FTW!
Old May 5, 2012 | 04:00 PM
  #35
TurboS10's Avatar
Transfer case has gone 8's....check youtube
trans is the issue -60E's don't last regardless of who built it -check the syty boards- they consider a refresh every couple of years for the mostly street builds.
4L80E swap needs a conversion input shaft for the transfer case as Dan mentioned. ~$600 IIRC
I got mine on a first run group buy considerably cheaper.
You find them for sale on occasion by someone moving on to a different project.
The V8 guys who tried cutting down the 80E output to the 27 spline 60E size broke them pretty quickly with strip use.
Nice build Jim/Dan.
What cam you running?
Old May 6, 2012 | 05:17 PM
  #36
danimal95's Avatar
Originally Posted by Mr.L88
I love the Sy/Ty and adding the extra V8 punch is just sick. I have always wondered what it would take to keep the transfer unit alive in one of these V8 twin type swaps.
nothing yearly fluid changes,mine has been flawless for the past 15k miles
thank you
Originally Posted by a4ls2goat
that is badass..
pre-heat,tig weld,post heat then cool naturally
yes dual 2.5 merged to a single 4" at the tb
Any updates?
yes we have been slammed at the shop just got back on it for final assembly it is looking very pimp-tastici will make a point to post more pics tomorrow
Nice build Jim/Dan.
basically the same cam that is in my truck honestly i can remember the specs but it idles smooth has killer rpm pull and has been proven to make power.the goals of this truck were basically the same as mine:drive it anywhere all power options still working as well as awd,as a matter of fact the owner recently to me he plans on driving it out to california when it is done
Old May 6, 2012 | 08:55 PM
  #37
David A. Cates's Avatar
How much different are the '10 camaro manis and the truck manis? I'm building a 1st gen S10, and plan to use flipped truck manis with the 5.3, and want to make sure that they will clear the stock steering shaft.
Old May 6, 2012 | 09:41 PM
  #38
danimal95's Avatar
they wont even come close,2010 are the only ones that will work to my knowledge
Old May 6, 2012 | 10:08 PM
  #39
What are you using for motor mounts?
Old May 7, 2012 | 12:18 AM
  #40
boost27's Avatar
Truck manifolds don't clear at all, passenger hit the top of the shock mount, and the driver side hit the steering shaft and the steering gear box. Well my experience with a 92 typhoon awd. 2wd drive might be different tho.
