CANNOT get clamshell mounts to line up
Any tricks here?
Are they bolted to the block in correct position?
What position are the frame pads mounted? Did you use energy suspension inserts?
I put new energy suspension inserts in my frame pads and could not get the clam shells to sit properly with the motor for nothing. Double checked the ES insert instructions multiple times and I knew I put them in correctly as ES instruct you to.. Had to remove them from the frame and flip the inserts and the motor finally aligned up correctly.
It seems if he had srilled and tapped the engine block holes higher, it would be perfect. I see Holley's mounts look like they have bump outs around the engine mount holes, as if hey are not in a straight line with the LS holes.
It's the crappy plates. These are what I got. I went and looked at carshops, and the drilled and tapped holes in theirs are down under the countersunk holes by about 1/2". Exactly what needs to be done. Darn it.
[IMG]
[/IMG]
