Accessory Drive- AC & Belt Fuel Pump??
Hey guys, trying to sort out what accessory drive I can use on the front of my LQ9.
It's a 67 Nova with TCI Pro Touring front clip. I have AC, PS, ALT & belt drive fuel pump. Fuel pump kit puts it down the bottom on the passenger side.
But every "factory" or GMPP front drive kit puts the AC there. Only ones that don't are the expensive VA kits. I don't want to spend $2000+ on a front drive setup.
Trying to keep everything as tucked in as possible. I need to fit two 67mm turbos in the engine bay.. Also trying to budget under $800. I already have sanden AC compressor that comes with the VA Gen4 setups & meziere electric water pump.
I like these two setups, but the AC is in the wrong position. Or would it just be easier to mount the pump up high next to the tensioner?
http://paceperformance.com/i-6255429...6-engines.html
http://paceperformance.com/i-6255430...7-engines.html
I think the CTS-V compressor might hit on my subframe though..
I have the ATI-917276 Balancer with 4-rib AC.
Any ideas?
Thanks, Jeremy
Any ideas?
Thanks, Jeremy
I like this one, but i'd have no room for turbos. Can't run them in front like an F-body. No room..
http://www.holley.com/20-132.asp
I bought this one...
and the AC will sit too low on mine and would have to cut way too much frame. I thinking of using this high ac mount for the corvette setup...
http://kwikperf.com/lsx_ac.html
I'm still researching which compressor to use.
