My 72 Buick Skylark Ls conversion build
Old Mar 3, 2016 | 06:47 PM
  #41
efregoso's Avatar
Originally Posted by Toddoky
Glad to help.
So with the Holley 302-2 oil pan, it should provide enough clearance. Will I still be able to use the UMI performance mounts or should those be changed as well to relocate the engine?
Like I said, I am running the th350 and its already bolted up, but the power steering pulley is hitting the power steering box.
Should I use mounts that relocate the engine or just get a smaller pulley?
Old Mar 3, 2016 | 07:42 PM
  #42
user 4737373's Avatar
The fore/aft positioning of the UMI mounts is obviously sufficient to allow you to install your TH350 behind your LS engine, but there's no data available that would tell me if they are able to provide you with an engine height that will allow you to take full advantage of the clearance geometry offered by the Holley 302-2 pan.
The ability to do so will become apparent to you once get to the point of trying to optimize your U-joint working angles. Both sets of the new Hooker A-body engine brackets were specifically designed to utilize the clearance provided by the 302-2 pan to drop the front of the engine as low in the chassis as possible; there are no other brand/type of mounting brackets on the market that provide the same advantage.
If you'd like more information, I invite you to check-in and post your questions in the Hooker 1968-72 A-body LS swap thread so we can eliminate further hijacking of the OP's thread here.
Old Mar 7, 2016 | 01:24 PM
  #43
"The Dude"'s Avatar
Great looking car! Very nice Build.
Old Apr 6, 2016 | 10:10 AM
  #44
indyc350's Avatar
Awesome build I just got my car done last year I got a 72 skylark with a 5.3/4l60e too. I didn't do it my self tho I had a shop do it, did you dyno your car?
Old Mar 8, 2019 | 12:08 PM
  #45
BigDave702's Avatar
[QUOTE=Anythinggm;17468008]Well guys my Skylark has been in the family since new. My grandfather bought it just a few months before I was born. The 350 is tired, so I've opted to bring it up to modern power and better MPG. bought a 05 5.3L/4L60E out of a truck and will be performing my first LS swap into the car. I look forward to learning a lot from you guys during this build, and I hope you enjoy mine. Here is a pic of my car and the donor engine.
http://i289.photobucket.com/albums/l...g?t=1370987312
http://i289.photobucket.com/albums/l...g?t=1370987357
http://i289.photobucket.com/albums/ll226/anythinggm/1972%20Buick/976366_10201055130010915_449843024_o_zps86505b22.j pg?t=137098735
Old Mar 8, 2019 | 03:01 PM
  #46
The last post on this build was just 3 years ago...
Old Jul 9, 2019 | 01:08 PM
  #47
Sheminator1's Avatar
I am well into my '70 Skylark restomod and am wondering what did you do for gauges? Did you change out the dash or is there a conversion kit out there to go from mechanical gauges to electonic?
Old Jul 9, 2019 | 02:47 PM
  #48
AGAIN, this is an old thread. None of the posters hang around here anymore.
Old Jul 9, 2019 | 03:31 PM
  #49
Well. A man can hope, right?
I was able to glean a lot of very useful information from this thread so I was hoping he'd still be around to answer my question.
Old Feb 28, 2021 | 06:06 PM
  #50
Moneymann BBriggss's Avatar
Default 1970 Buick skylark ls swap
I’m doing a swap in my 1970 Buick I’m trying to see how did you end up getting the eve hooked up and getting the petal placed correctly
Old May 18, 2022 | 04:46 PM
  #51
Redneckracing's Avatar
Default Headers
[Q UOTE=Anythinggm;17468008]Well guys my Skylark has been in the family since new. My grandfather bought it just a few months before I was born. The 350 is tired, so I've opted to bring it up to modern power and better MPG. bought a 05 5.3L/4L60E out of a truck and will be performing my first LS swap into the car. I look forward to learning a lot from you guys during this build, and I hope you enjoy mine. Here is a pic of my car and the donor engine.
http://i289.photobucket.com/albums/l...g?t=1370987359[/QUOTE]
What did you use for headers. I’m doing an ls in a 71
Old May 18, 2022 | 05:50 PM
  #52
Somebody's not paying attention.....
Old May 19, 2022 | 02:10 PM
  #53
Jimbo1367's Avatar
Originally Posted by g atsma
somebody's not paying attention.....
lol. 😂
