LY6 into a 55 Nomad Swap
Thank You,
Tory
The LS3 intake will fit using the truck water pump and throttle body, by shaving a little material off the water pump where the upper neck presses in. I have an LY6 with an LS3 intake, but my intake is mounted backwards (tube chassis offroad race truck, forward-mounted air cleaner would be clogged shut within a mile).
Read these threads:
https://ls1tech.com/forums/generatio...y6-intake.html
https://ls1tech.com/forums/generatio...-manifold.html
http://www.chevyhardcore.com/tech-st...he-difference/
Is a Main Girdle necessary when using a LSX Block?
http://www.dmperformance.org/ls6.html?1171930449750
Thank You for the advice.
