Coolant Temperature Sensor mounted on the steam hose coming from the water pump?
I was looking to install a water/coolant temperature sensor, i don't want to remove the existing electrical sensor that is on my drivers side head or drill and tap the passengers side head. i heard a reading can be taken from the water pump or the steam/bypass hose running there by using a T. how would i go about doing this?
here is an image of the bypass hose running from the water pump i hope to T my coolant temp sensor into. any ideas? thank you
also, i have this plug on the passengers side of my block.
would something like this work?
which seems to be part number Equus 9848
I have one ran inline w/ the top hose, reads fine... when the thermostat is open. If I'm watching the computer I can see when the temp it 190 and then the gauge in the dash finally swings to 190.
One more thing on my to do list.
