LS3 conversion wont start! Need some help.
I am getting 68 psi of fuel pressure on the a-pillar gage and the gage on my regulator. I can here the fuel pump prime when I turn the ignition key. I also tried a spark tester between the coil and spark plug and got nothing. I tested for injector signal pulse and got nothing either. Can anyone give me some direction where to start? This is my first EFI swap so any help would be great.
Oh, I also hooked up my Actron OBD II and found no error codes.
Thanks,
Jeff
But if your not getting Plug Spark or Injector pulse.. would check the power to the ECM, that being the IGN power and that it is not cutting out. check the Grounds. check to make sure all sensor connectors are good.
Can't help much without more info on what works and what doesn't. What is getting power and when ...
BC
Thanks,
Jeff
I have checked all of that. I have went as far as going right to the battery to power the ECM. I still get the same result.
