Cruise control wiring
Anyone who has experience from this ?
M
Also do you have the serial data connected between the TAC module and the ECM? Also do you have the brake switch connected to the TAC module.
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
The HND2 is the dash mounted switch and is the ONLY one that will work without relays. The HND 3 Will need relays.
I can get the setup have one on a 40 ford with ls motor works great
Since the brake switch on my car connect to earth when braking I have a relay connected to this that make it possible to invert the signal and use it for +12V on/off.
At the moment I have a momentary swith that apply +12V to TAC C1, Pin 14 and feed a 2-way rocker switch that I can toggle between TAC C1, Pin 4 (set/coast) and TAC C1, Pin 5 (resume/accel). Would that work?
LS1Nova71, why do I need relay for the HND2 and not HND3?
Magnus
Magnus
As for why the das mounted DD switch doesn't need relays, its because the switches in it are normally open, like a GM switch where as the turn signal lever DD switches are normally closed. Why they did that I have no idea but have seen a lot of people try to use the TS mounted switches and have problems with them. I'll try to find the thread that shows how to wire the relays.
