Fb rx7, ls3, t56, 8.8 fast and cheap
Old 07-06-2013, 01:42 AM
Grr
Grr's Avatar
Default Fb rx7, ls3, t56, 8.8 fast and cheap
I don't come on tech much lately, just nothing like it used to be here with all the retarded kids. But alas I figure this will help a few people out, so here is a rundown of my latest build.
I grew tired of my camaro, again, so I parted it and crushed the body, it was in poor condition anyway. I wanted to go fast with a t56 again and knowing their limitations it was going to have to be light, and cheap. The only option In this case is an FB.
I had a built ls3 and built 4l60, so that got traded for a t56. In short time I found a suitable roller for a great price and picked it up, 84 gs In the great blue I like. This happened on may 15th 2013
It's in Good shape with the only rust being in front of the rear tires and the upper control arm/wheel well area.
At this point I laid out doing 5 lug, brakes, and modding the steering and oil pan. **** THAT. Picked up a complete tII front suspension and steering column.
That was done as well. At this point I gathered 2 8.8s and shortened one with 3.73s and limited slip, and installed that.
I settled on gto engine stands so I would have a vertical plane to adjust engine height, or to add rubber mounts. So I welded up some pads on the subframe and use a stack of washers as my solid mount, I will make aluminum spacers next time it is out. At this time I also built a quick battery box.
For the trans crossmember I cut the factory mount bubbles off and reattached them toward the rear. The crossmember is a piece of bent pipe, this give me allot of exhaust room and again a vertical plane for adjustment of height.
Old 07-06-2013, 01:55 AM
Grr
Grr's Avatar
As parts came in I did my integra speedo conversion and stripped the engine harness. In my camaro I ran bbe 1.75" headers 2.5" y and a single 3" exhaust, it was terrible. I knew that with the proper exhaust I could get around 540whp, but good luck finding it premade. So I ordered everything and got to work.
Headers are 1/2" flanges, because I hate leaks, and 2" 16ga stainless. Collectors are slip on 2"/3" velocity merge ebay pieces which are fantastic for the price. Equal length was not going to happen with 2" though I tried, but shortest tube is 27" and longest is 33".
It took probably 9 different layouts to get a good fit and be able to remove the starter etc. I do have to remove the starter and lift the motor to get the pass side in, drivers goes in with one hand.
As you can see they fit like a glove and tuck up very tight, they are not lower than the trans, oil pan, or crossmember.
Old 07-06-2013, 02:07 AM
Grr
Grr's Avatar
Tis week I built a watts bracket, since grannies is impossible to work with, and got the driveshaft length set. I used my stock camaro shaft and the stub off the explorer 8.8 since they use the same size tube just cut to length and put together.
26x7.5-15 Mickey sportsmans I had laying around on FC 15x6 rims, 34# each total
Howe radiator, hoses done, plugs and wires in, wiring done, brakes almost done. Waiting on front brake hoses and the fuel system currently. It is home in the garage at least to finish small stuff and get it running
Feel free to ask any questions and I will respond best I can and include pictures if needed
Old 07-06-2013, 06:56 AM
sierrac3_s2000's Avatar
Do you have any photos of the speedo conversion? So far the swap looks great. Should be a fun car.
Old 07-06-2013, 08:04 AM
Grr
Grr's Avatar
The speedo conversion is one thing I did not take pics of. I removed the guts of both and swapped faceplates, the wiring attaches to appropriate screws on the back of the unit. It is mounted with 2 screws drilled through the circuit board and spaced with nylon spacers. When itiwas done I filled the back cavity with a bunch of silicone to prevent vibration
Old 07-21-2013, 09:39 AM
Grr
Grr's Avatar
As an update, finished the car last week and have about 75 miles on it now. It's pretty much rediculous to drive. Ran around with open headers for awhile and yesterday I built the front half of the exhaust.
It is all stainless dual 3" with x pipe, dynomax short bullets in the front and another set of full size bullets going in the rear.
Short 2nd and 3rd gear pull, 30-95 or so with open headers
Idle vid yesterday with the half exhaust on it
Still needs a bunch of work, has a front end shake and needs alignment. It hooks incredibly well even on these **** 215 snow tires
Old 07-21-2013, 09:42 AM
Grr
Grr's Avatar
For reference the build is
Forged ls3 378"
706 heads 2.02 1.6 valves ported
12.28 compression
Eps 238/246 111+3
Super victor, accel 1250cfm 4150 tb
2" headers dual 3" exhaust
Monster stage 2 and t56
8.8 axle with 3.73 gear
Btw, it weighs 2550# with a full tank and no driver, and I have done no weight reduction anywhere yet.
Old 07-21-2013, 09:51 AM
DEFYANT's Avatar
Nice build man. Get a deal on the LS3?
Old 07-21-2013, 10:06 AM
Grr
Grr's Avatar
Kind of, it's STANGKILR's old nitrous motor out of the silver camaro. It was blown to **** all I saved were the block and rods. New pistons, crank ground bearings. Probably have $2600 in the shortblock
Old 08-03-2013, 09:20 AM
Grr
Grr's Avatar
finished the exhaust, will get some videos up in the next couple of days
Old 08-03-2013, 11:46 AM
CattleAc's Avatar
That entire exhaust is very impressive...did you weld it up yourself...???
Old 08-03-2013, 11:48 AM
Grr
Grr's Avatar
yes it is all TIG welded, I made the entire setup from the x-pipe back on Thursday.
Here is a video introducing the car, I have 320 miles on it now and have been working some of the bugs out of it
Old 08-03-2013, 01:08 PM
bczee's Avatar
I have a 79' sitting in the side yard...
I'd be more interested in the mounts, pan, accessories. What radiator did you use ? Swap parts and mounting were used. .?!
BC
Old 08-03-2013, 01:59 PM
Grr
Grr's Avatar
GTO stands
f-body oil pan and accessories
Radiator is a Howe shelf item,#342AA, 27"x16.5"x3". getting rid of all the FB stuff up front allowed me to cut the tension rod brackets off and run a much larger radiator.
Mounts were all made in the shop
Old 08-04-2013, 07:59 PM
Tig
Tig's Avatar
That's is awesome and sounds great.
Lets see some vids of it in action
Great job man
Old 08-04-2013, 11:04 PM
vazfx16's Avatar
Well done. The acceleration video was like something from a cartoon. WOW!
Impressive.
Thanks for sharing.
Old 08-05-2013, 10:26 AM
Grr
Grr's Avatar
Being that its such a tin can, its just too loud inside with the bullets. I ordered some round magnaflows for it. Also ordered new wheel studs so I can get my drag radials put on.
I got after it pretty hard yesterday with the 215 snow tires on the back, bent one of the lower control arms LOL. So I need to pick up the steel to sleeve those this weekend.
Old 08-05-2013, 11:54 AM
ig109's Avatar
Damn.. be hard to get any street races sounding like that.. Now get some bigger brakes on that thing and some rubber too!! lol
Old 08-05-2013, 12:15 PM
ctd450's Avatar
Nice fabwork! Don't see too many here making their own mounts, headers, driveshafts and such.
Are you replacing the front shorty or rear full length bullets?
Old 08-05-2013, 12:24 PM
Grr
Grr's Avatar
I am replacing the rear full length bullets, the shortys are permanent and just used to get rid of the rasp
It has plenty big brakes, 10.5" turbo 2 brakes and 4 piston calipers in front, 10.5" disks in back. god damn thing stops on a dime it actually has a little TOO MUCH brake they are touchy
Tires got put on the car last night but will change the studs this week. Running BFG 235/60-15 drag radials. That is plenty of tire at this weight to run bottom 10s and still last a couple thousand street miles
Quick Reply: Fb rx7, ls3, t56, 8.8 fast and cheap
