4l80e hard shifting
Old Jul 6, 2013 | 04:19 PM
mooseknuckles's Avatar
Default 4l80e hard shifting
I hope someone can help..I have a 86c10 with a lq4/4l80 and after the tranny is warmed up it shifts very hard in every gear...it has always done this, its a PSI Conversions pcm and harness. I have tried switching the ISS and VSS sensors around, checked the trans harness plug, not sure what to look for?...I do not have the wire for the park/neutral ground hooked up to the neutral safety switch because mine only has the single plug for the back up lights.....it keeps throwing this code...
Old Jul 7, 2013 | 10:22 PM
seventy7 caprice's Avatar
not an expert but i think thats your input speed sensor to the trans, it senses the speed the cranks spinning not the output speed. you need a real time scanner to make sure the sensor is reading correctly or reading at all. my car did the same hard shifting till i had the sensor hooked up correctly.
Old Jul 8, 2013 | 07:19 AM
Old Geezer's Avatar
- Faulty Transmission Speed Sensor
- Transmission Speed Sensor harness is open or shorted
- Transmission Speed Sensor circuit poor electrical connection
Some check points.............
Old Jul 8, 2013 | 06:56 PM
thank you....
Old Jul 10, 2013 | 05:17 PM
I got a new input speed sensor...see how that works.
Old Jul 14, 2013 | 01:55 PM
got the new sensor in and still throwing the same codes...
Old Jul 15, 2013 | 02:02 AM
ls1nova71's Avatar
Do a continuity test between the plug and the PCM. Make sure its not open, shorted to ground or shorted to power.
Old Jul 17, 2013 | 02:57 PM
tried that I got nothing....
Old Aug 3, 2013 | 09:22 PM
maybe this is why....
Attached Thumbnails 4l80e hard shifting-img_0595xxx.jpg   4l80e hard shifting-img_0611.jpg   4l80e hard shifting-img_0610xx.jpg   4l80e hard shifting-img_0615.jpg
