neutral safety plugs
Old Jul 6, 2013 | 07:41 PM
dobbs187's Avatar
Default neutral safety plugs
Where can I buy them and how much 01 style 5.3 truck harness
Old Jul 6, 2013 | 07:49 PM
BP Automotive's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
We have them. The cost for both of them is $32
The cost for the newer style is $27
Both connectors can be color coded to your application for easy install!
I recommend getting the newer NSS and using the newer connector. The newer doesnt have the Dielectric compound leakage problem the older one has.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old Jul 6, 2013 | 11:25 PM
LSx '85 C10's Avatar
Are the newer ones for the single plug NSS? and is it a pigtail?
Old Jul 7, 2013 | 07:59 AM
LS1Tech Sponsor
Yes it is the single connector. I quoted pigtails, not just the connectors.
__________________
1-888-467-4491
Old Jul 7, 2013 | 06:32 PM
dobbs187's Avatar
Reason for wanting to stay with older is because my napa wanted 120ish for newer style and 70ish for older one where is the cheapest place to get these switches?
Old Jul 7, 2013 | 09:38 PM
shoeboxvette's Avatar
Try Amazon 2 plug style was $35.00 the single plug is $42.00
Old Jul 7, 2013 | 09:45 PM
Default Neutral safety Plug
I'm Interested in a newer style plug I've got a 4l60e out of an 2004 gto I would also like to use the wiring from trans for neutral safety switch and reverse lights. Sent PM also
