5.3 into a 72 Chevelle
I still got a little cleaning up to do but it doesnt look too bad. The ECM is under the air filter. I bought a cold air intake for a truck and modified it a little. The fans are from a Cougar and the radiator is stock but was not very old. I bought a supposedly built 4l60E and a Jegs 3500 rpm converter. My mounts are the 1'' setbacks and frame stands are the originals in the original location. I modified the stock cross member and used it. I had to BFH the trans tunnel to get the trans to work and I am using the stock shifter with the shift works linkage. I havent got the speedo working but am planning on using the cable X box that drives the original speedo. I want the car to appear until you lift the hood.
These are out of a 2006 Honda Accord Coupe. The allow for much easier access to the rear seat and are much more comfy than the 42 year old bench seat. Once I get the rear seat recovered I think they will look great.
