Power steering ??? 79 malibu
Did you put the old pressure valve into the new pump? Most G-bodies are mostly metric and work with a lot of the new stuff... but I'm not sure if your Bu is still mostly SAE sizes/threads.
I think even the LS valves work with the pressure lines, pick one up at the local parts store and see if it will work. You might not mind the steering feel but I read about others' complaints and decided to just run a Monte Carlo valve and toss the truck valve.
Or you can look for a place that makes custom PS lines...
Or you can run -AN lines/fittings/adapters for a "build your own" custom line
