Wont start and smoke from cooling system
Old Jul 20, 2013 | 06:47 PM
Swapper's Avatar
Default Wont start and smoke from cooling system
alright so ive been trying to fire up this motor for the past week and it just doesnt wanna fire. ive gone through the wiring 3-4 times, checked codes and all i get is for evap crap (which i thought was tuned out). computer was a mail order from a company ive used several times with no issues. this is what i had them tune it for just to fire. (2001 4.8l, 2000 4l60e, 3200 stall, 60lb injectors and vats removed). i have fuel and spark.
anyways when i crank it over with no coolant in the motor i get what looks like exhaust smoke from the thermostat housing and waterpump. any reason for this? ive never seen it before and ive done maybe 5-6 swaps.
any help would be greatly appreciated.
Old Jul 21, 2013 | 02:16 AM
bczee's Avatar
Might be a cracked block or a blown head gasket...did you try a compression or leak down test ? Or even a smoke test...
Old Jul 21, 2013 | 02:26 AM
Swapper's Avatar
nope he bought the motor off craigslist and we threw it in. guess ill have to try and do a compression test.
Old Jul 21, 2013 | 08:53 AM
Pop N Wood's Avatar
When my head gasket went I got bubbles from the radiator and coolant leaking out of the exhaust.
A leaking head gasket shouldn't keep it from starting. Maybe multiple issues.
Old Jul 21, 2013 | 02:02 PM
Swapper's Avatar
yeah dunno why it wont start. i got good fuel pressure (around 60-65psi), i know the injectors are firing cause i pulled the rail off and cranked it over with the injectors still in it and watched the pattern. i got spark so i know its not the computer. totally forgot what the IAT controls so i hooked one up today and still nothing.
Old Jul 21, 2013 | 02:09 PM
Swapper's Avatar
and if it was the crank sensor i shouldnt get spark right?
Old Jul 21, 2013 | 08:28 PM
Swapper's Avatar
owner decided to replace the gas today. stuff that came out didnt smell too good. went through and tried several other things and still cant this thing to fire on its own. itll run fine spraying something into the throttle body. pulled the rail off and a spark plug and theyre both firing at pretty much the same time. tried different spark plugs. pulled the intake off to check for any messed up gaskets. checked to see if the fuel filter was hooked up correctly. checked all wiring yet again.
dunno what else it could be.
oh heres a vid of the smoke coming from the waterpump:
Old Jul 21, 2013 | 09:39 PM
MrPotatoeHead's Avatar
That looks like all the compression is going right out of the cylinders into the coolant passages. Sounds like one or two cylinders has compression just not enough to start.
Old Jul 22, 2013 | 05:16 AM
Pop N Wood's Avatar
That thing's toast. Quit trying to run it and pull it apart before you damage something else.
Old Jul 22, 2013 | 06:49 AM
Old Geezer's Avatar
What happens when you "throw things together".............
Old Jul 22, 2013 | 09:55 AM
Swapper's Avatar
Guess I finally got a bad one. Not bad 1 out of 6. I knew it was to good to be true. Well hopefully its only head gaskets.
Old Jul 22, 2013 | 02:16 PM
Swapper's Avatar
looks like im goin to be pullin the heads, checkin the block, putting new gaskets and some 317's with studs now.
