V6-v8 fuel pump problems
Don't use the vette regulator and the Delphi fuel bucket at the same time....simply add a T like I did in the above pic. The Delphi "magically" regulates the fuel...sends what's left over back into the bucket...and the correct pressure down your "V6" fuel rail.
If you don't have a short fuel line to "T" the fuel feed back into the bucket...go to napa or another parts store....be sure to tell them it's for ~60psi fuel pressure.
Does anybody have ideas on where to buy stock fuel lines? I can't find a part out local, and shipping would be outrageous.
Leon
Now I need to do the trap door method to remove the pump and fix the hose. I just had my 3" exhaust welded up so I can't drop the tank anymore.
