Project "SVT Chevy" now blown!
Old Oct 4, 2013 | 01:47 AM
  #41
Swapper's Avatar
theyre really not that hard. honestly i thought they were goin to be alot harder but i was wrong. well it also depends on what your swapping into and what kinda mods and stuff you wanna do.
Old Oct 5, 2013 | 05:34 PM
  #42
YungSteph's Avatar
I'm doing a 5.3 turbo swap in a 1996 roadmaster. My biggest fear is wiring and tuning. Fitting shouldnt be an issue seeing as they sell swap mounts for everything imaginable.
Old Oct 5, 2013 | 07:50 PM
  #43
Swapper's Avatar
Wiring isn't bad.I used to be afraid of it but now I've done several harnesses and learned that they're actually pretty easy. Especially with that Lt1swap.com site.
Old Oct 5, 2013 | 08:41 PM
  #44
YungSteph's Avatar
I wouldn't be scared of a standalone but trying to merge the 2 together to make the speedometer and ses light work is what seems to be a tall task
Old Oct 6, 2013 | 12:52 PM
  #45
Swapper's Avatar
oh yeah trying to find diagrams and stuff for your car is kinda apain. i know when i did my 3 gens they have soo many different pin outs for the firewall plug.
picked this up a couple weeks ago for $70.
picked this 4l60e up yesterday. says its rebuild with soem decent stuff and a shift kit.
Old Oct 7, 2013 | 07:34 PM
  #46
Swapper's Avatar
well this past weekend besides picking up that trans i picked up a free set of headers. oh also got a turbo hotside for a LS swapped fox body. dont think ill be keeping it though.
headers are 351 swap headers with LS flanges. buddy built them for his 5.3l fox with the same k-member but was scared of the k-member so went a different route.
and my new favorite pic:
Old Oct 7, 2013 | 09:21 PM
  #47
Busa_rob's Avatar
Dude. Compound boost.
Old Oct 7, 2013 | 09:51 PM
  #48
Swapper's Avatar
lol my buddy said the same thing!
Old Oct 7, 2013 | 10:22 PM
  #49
BigEd_72455's Avatar
All these pictures of stuff OUTSIDE the car!!! Come on MAN!!! INSTALL IT ALREADY!!!
You have everything but the wiring harness and ECU that I can see... Pull the trigger!!
Old Oct 7, 2013 | 10:39 PM
  #50
Swapper's Avatar
well its kinda my daily driver. im waiting to get most the parts together. the trans i bought needs to be gone through and i cant afford it yet. plus i gotta take the motor back to my buddies house (hopefully sometime soon) to finish the blower box.
i do have a harness but no ecu at the moment.
trust me ive been wanting to start on it already.
i might just start pulling it apart here soon before the weather starts getting bad. although im in california. lol
Old Oct 7, 2013 | 10:46 PM
  #51
Have you given any consideration to how hard its gonna be to get those intake bolts out for the carb side? Or do you have an idea of access holes when the supercharger is off? And also, that supercharger pulley is 8 rib where the rest of your accessory stuff is 6 rib. How ya gonna run that? And did you take that into account when building the intake adapter?
Old Oct 7, 2013 | 10:56 PM
  #52
Swapper's Avatar
theres holes on the top of the box to get the bolts in/out. just goin to run the 6 rib stuff. we made it so the belt is goin to ride in the middle of the blower pulley. actually the blower pulley is a 10 rib. so well hae 2 ribs on each side it can move around on.
Old Oct 11, 2013 | 08:15 PM
  #53
tonypaul's Avatar
I really like where this is going!!!!!
A few years ago I seen a guy do something similar to what your doing but on a jet boat. He tried putting a supercharger from a newer Pontiac 3800sc on a Olds 455. The problem he had at first was the the belt would pull down on the snout seperating the blower from the adapter he made from the intake. He ended up putting some support braces under the snout to the intake to help the belt pull.
From the pics it looks like it might could be something to consider...
Just thought I would add that to your thought process in case you run into any problems...
Old Oct 11, 2013 | 08:24 PM
  #54
the only problem with it MOVING AROUND is when it moves on that one, it will move on the rest and then go flying off and get wrapped up around your driveline.
Old Oct 13, 2013 | 12:41 PM
  #55
Swapper's Avatar
well like i said before the box isnt done. well be adding a lower support/idler pulley bracket to the front of the box thatll bolt to the front bolts of the valley cover.
we lined the belt up pretty good. if it does come off oh well. i dont drive fast or crazy so i dont think itll happen. i just build these things to say i did it.
Old Oct 13, 2013 | 05:50 PM
  #56
Swapper's Avatar
so decided to pull the motor out today.
Old Oct 14, 2013 | 02:01 AM
  #57
Swapper's Avatar
so right after i pull the motor this shows up in my driveway. I was like cool my new motor for the mustang! lol
Old Oct 14, 2013 | 08:36 PM
  #58
Swapper's Avatar
so got home and pulled some more stuff out and pressure washed the engine bay. posted the motor/trans and stuff up on craigslist. painted some parts of it but need to pull more stuff out and scrub it down a little.
Old Oct 14, 2013 | 09:12 PM
  #59
Have fun!! If I would have been able to get them, I would have bought long tubes for my S-10 also. But $850 for a pair was just too far outside my one shot budget.
Best of luck with it and I hope you don't have to go too hog wild on the hood getting something to fit. Otherwise it will all just be too much in the way.
Old Oct 14, 2013 | 09:30 PM
  #60
Busa_rob's Avatar
Engine bay cleaned up very nice.
