Project "SVT Chevy" now blown!
Old Nov 12, 2013 | 06:45 PM
  #101
Swapper's Avatar
thanx
lol neat. sorry dont hear that word too much.
Old Nov 14, 2013 | 01:37 AM
  #102
Blackbob's Avatar
Its coming along nicely !
Old Nov 14, 2013 | 01:43 AM
  #103
Swapper's Avatar
Thanx. Still need alot of stuff but i'm going to try and get it at least fired up within the next couple weeks. Just waiting on paychecks.lol. So far they're all going to the car.
Old Nov 14, 2013 | 01:48 PM
  #104
ion05's Avatar
Let me know how the spring perch goes from Aje have the same set up. Great build
Old Nov 14, 2013 | 02:39 PM
  #105
Swapper's Avatar
Will do. Guessing it should be like stock. I need to find springs now cause i'm still on cut 4cyl springs.
Old Nov 16, 2013 | 02:45 PM
  #106
Swapper's Avatar
so ordered my fuel rails, starter and bought a steering shaft.
was goin to pull the diff out and drop the tank today but was a little cold and dont feel like laying on the cold cement.
decided to do this today.
Old Nov 17, 2013 | 04:00 PM
  #107
Swapper's Avatar
weather was a lil bit nicer today so decided to drop the diff. wasnt as hard as i thought it was goin to be.
the parts pile:
ever see a tire blow out while just sitting? i was driving on this before i pulled the car apart and it was good when i sat it in the backyard.
Old Nov 19, 2013 | 07:12 PM
  #108
Swapper's Avatar
well i didnt win the fuel rail battle. need either do some grinding or some spacing. also got my steering shaft today.
Old Nov 23, 2013 | 05:08 PM
  #109
Swapper's Avatar
todays projects were installing the headers, mounting up my delete plates, and making my intake fit the fuel rails now.
Old Nov 25, 2013 | 02:29 PM
  #110
4eyedcoupe's Avatar
What headers did you end up going with?
Old Nov 25, 2013 | 06:56 PM
  #111
Swapper's Avatar
351 swap headers with LS flanges that my buddy made for his 5.3 swapped mustang.
was kinda worried they wouldnt fit cause his was a stick and mines a auto.
Old Nov 30, 2013 | 05:35 PM
  #112
Swapper's Avatar
well fabd up some coil pack relocation brackets. gotta paint them, run the wiring and wrap the plug wires and coils with some summit racing heat tape. yes i know theyre a little close to the headers but i think itll work, if not then ill move them. also got another freebie the other day, buddy gave me a set of sn95 front calipers.
fab'd up a bracket for my pcm to mount under the dash.
went to the junk yard today cause it was 50% off and picked up some GT sway bars and a newer cobra bumper.
the packs arent tightened down in the pics.
cobra bumper i found. then i rough cut it, gotta get my air saw and do the finer cut.
Old Nov 30, 2013 | 05:41 PM
  #113
Swapper's Avatar
general idea. his is a different year bumper but i like my version better..
Old Dec 2, 2013 | 06:16 AM
  #114
Blackbob's Avatar
How did the bumper turn out ?
Old Dec 2, 2013 | 09:05 AM
  #115
Swapper's Avatar
Dunno still gotta in it. Need to take it to work but my boss from corporate is going to be here this week. He's cool but I know I'll be busy while he's here. Trying to fix a bunch of OSHA stuff.
Old Dec 7, 2013 | 05:11 PM
  #116
Swapper's Avatar
well got a bunch of stuff the other day. pretty much all my fuel stuff, and trans dipstick. waiting for my battery relocation stuff still. was supposed to be here this past week.
anyways weather cleared up enough for me to get some work done.
hooked up my fuel rails and threw the rest of the fuel line to the back of the car (floor is all wet so didnt do anythign else with the fuel). installed my dipstick which needed some grinding to fit, and mounted my passenger side coil packs but i need to do the wiring for them. oh also found out that my boss will let me build my power steering hoses at work so i mocked up some fittings.
oh found out that 2003 3500 silverado 8.1l plug wires were perfect for what i needed. they come out off the spark plug at pretty much a 90 degree angle and are a little longer then f-body and the truck wires.
dont mind the wiring im not done yet.
sorry for the crappy pics my cameras flash decided to stop working.
Old Dec 8, 2013 | 04:24 PM
  #117
Swapper's Avatar
finished up some more underhood wiring, bolted down the cereal box, supercharger, throttle body elbow, throttle body, and ran fuel line to back of car. still need to drop the tank and install the new pump and vette regulator. still waiting for my battery wiring stuff.
Old Dec 9, 2013 | 01:15 AM
  #118
Blackbob's Avatar
Coming along nicely I see,how much longer do you think you have untill you can turn key ?
Old Dec 9, 2013 | 01:45 AM
  #119
Swapper's Avatar
Probably another paycheck until I can fire it hopefully. Need to finish up the fuel line stuff, hook up the Trans lines, disable vats, run battery cables and put fluids in it.
Old Dec 9, 2013 | 02:43 AM
  #120
Blackbob's Avatar
Sweet man,not too long at all.
