Project "SVT Chevy" now blown!
Old Dec 31, 2013 | 09:44 PM
  #141
x275radial's Avatar
im not knocking you. love when people do stuff like this and get it done rather than talk about it. the throttle body tube you might wanna make a support bracket that actually bolts on, the welds don't look strong enough and under street driving all the vibration could crack it. wouldn't wanna see this thing get stuck wide open and wrap it up.
second I would have spent a couple more dollars for the holley high ram. you might have been able to make a nicer transition plate for the blower. but once again not knocking, just a couple things I would have done.
Old Dec 31, 2013 | 10:00 PM
  #142
Swapper's Avatar
the welds on the throttle body tube are actually pretty good. if i remember correctly my buddy also welded on the inside of the tube. but i will take that into consideration.
i went with the vic jr cause 3 reasons. first, i wasnt sure this whole thing was going to work so i figured i didnt wanna spend much on somethign i wasnt sure of. second, this is concept number 1 and we were thinking of cutting this manifold up and building our own manifold that we were goin to try to intergrate a air to water intercooler in it. and third is clearance, honestly i didnt want it stickign out fo the hood as much as it does but thats where it is. i think with the holley itd be alot higher.
i still dont know if ill even be able to drive this without getting hassled by the cops but i guess ill have to wait and see.
Old Dec 31, 2013 | 11:06 PM
  #143
x275radial's Avatar
lol well once again please don't think I was bashing you. just figured I throw some stuff out there I do this for a living and have seen a lot of projects and figured the hi ram would have made a better manifold setup or the holley short ram, still uses the same plate form for top plate. but once again very creative. but the welds are not that great looking been welding for 20 years and that would never leave my shop. keep up the good work would like to see some dyno numbers.
Old Dec 31, 2013 | 11:13 PM
  #144
Swapper's Avatar
thanx wasnt takin any offense. yeah he was having kinda an issue with the thickness of the metal from the intake tubing and the flanges. dunno how much aluminum welding he has done but there was no leaks which is all i cared.
Old Dec 31, 2013 | 11:15 PM
  #145
x275radial's Avatar
k kewl good luck man. once again love what your doing.
Old Dec 31, 2013 | 11:21 PM
  #146
Swapper's Avatar
thanx
Old Jan 1, 2014 | 06:33 AM
  #147
Tuckin15s's Avatar
What a crazy interesting build! It's pretty awesome.
Old Jan 1, 2014 | 03:49 PM
  #148
Swapper's Avatar
thank you sir. got a build thread on your s10? i got pretty much the same truck but its stock, thought about swapping it to a 4.8 or 5.3 mostly just for gas mileage cause the 6 banger drinks gas.
Old Jan 2, 2014 | 06:27 PM
  #149
Swapper's Avatar
after 3-4 weeks in the body shop i finally got my wheel centers back. now to spend 3-4 weeks putting them back together. lol theyll look good with some 255/50/16 slicks on the back.
the pics dont do them justice....
Old Jan 5, 2014 | 05:21 PM
  #150
Swapper's Avatar
did some more wiring, bolted up my front suspension and threw my roller wheels on. looks like i might need some new springs/ shocks cause the exhaust is pretty much sitting on the ground.
Old Jan 5, 2014 | 09:13 PM
  #151
Swapper's Avatar
picked these up from my buddy to get some test fitting done. (cross fingers) i hope i can get them to fit. MoAr TrOlLiNg!!
Old Jan 6, 2014 | 06:32 PM
  #152
FrossB's Avatar
Awesome build man. Your car started off identical to mine. Picked it up for 700 bucks in really good condition. Ill be starting my build (typical 5.3 turbo) build here soon!
Sub'd!
Old Jan 6, 2014 | 06:46 PM
  #153
Swapper's Avatar
nice man. yeah ive done a couple turbo builds but ive never done a blower so i decided to give it a try.
mocked up the z06 wheels. looks like with the adapters im looking at the might work. might rub a little if i go lock to lock but it might work.
with suspension compressed:
Old Jan 6, 2014 | 07:22 PM
  #154
FrossB's Avatar
How much did that muscle car pan hang below your k member?
Old Jan 6, 2014 | 09:14 PM
  #155
Swapper's Avatar
Oh is not the muscle car pan. It's a ls2 Gto pan.
Old Jan 6, 2014 | 10:56 PM
  #156
FrossB's Avatar
Oh my bad lol Idk where I got that it was a muscle car pan. Probably mixed it up with another thread.
Old Jan 7, 2014 | 03:25 AM
  #157
Blackbob's Avatar
I like the Z wheels ! When do you think you'll have those bolted on with a tire ?
Old Jan 7, 2014 | 09:10 AM
  #158
Swapper's Avatar
It'll probably be a little while they've been cutting my hours at work so my check is going to be small. I do have 2 tires I can throw on. Would need to by wheel adapters though. I might just order them.
Old Jan 7, 2014 | 10:54 AM
  #159
AGearHead4Life's Avatar
Awesome build man. Thanks for sharing the link on my FB page. Subscribed! In for the rest of the show.
Old Jan 7, 2014 | 02:11 PM
  #160
Swapper's Avatar
thanx.
