LS powered Bavarian Monster
The day I brought my $1000 99.576% rust free monster home.
I have always been a fan of swaps, and I'll get it out now, this wasn't originally going to be a LS motor swap, rather a 302. but after a buddy talked sense into me about cost, reliability and power potential it just made sense to come over to the dark side!
A list of everything I have done so far, and what is still to come.
- Car was fully stripped to nothing
- all under coating was removed
- minor rust areas repaired
- entire chassis, front to back, top to bottom, inside and out was stitch welded
- sunroof and hvac removed
- spare tire holder removed
- rebuilt M3 steering rack installed, 2.8 LTL
- Full 5-lug conversion from 98 M3
- Custom built coilovers front and rear using Koni externally adjustable shocks and Ground Control coilover equipment
- Ground Control Race camber plates
- solid Eyeball CAB's
- Poly everything bushings
- M3 brakes
- Manual brake conversion
- Modified rear subframe for camber and toe adjustment
I think that's everything I have done so far, here are things yet to come.
- Full roll cage (finishing up the bender in the next week hopefully)
- LSD & half shaft rebuild
- LM4, LM7 OR L33 LS motor ( have a couple combinations, not sure on which setup yet)
- Transmission - TH350 with full manual/engine braking valve body, T5, or 4L60/80E (weight and budget are a factor here. 6spd would be nice, super heavy.)
- Custom exhaust - by me
- fiberglass hood (possibly roof skin)
- paint
- wheels
Now a picture story of some of the Done aspects of the car.
First part to come off the car
4 hours later......
Stripped all the sound tar inside
Ground the seams
Started to Stitch weld
Pulled the wiring harness
First roll on the rotisserie I built
Started to strip the undercoat
Front jack points were the only really rust part, fixed that.
Made rear shock tower reinforcements
More stitching.....
Ok you get the idea, onto suspension. On the left is a gutted M3 shock, on the right is the same housing on it's way to be a coilover. you have to remove the perches.
All cleaned up.
Sleeve stops welded on
The goods!
All assembled and painted
New 5-lug setup on!
Loaded up and moving to new shop!
Say Hi to my grandma!!
New home!!
New toys!
Slip roll, notcher, bead roller and edge crimper!
And....so I can install the cage! I am build an exact copy of this air/hydraulic tube bender!
So there you have it, a very abbreviated version of the build so far. Not a whole lot of LS action yet....none actually but it'll happen very soon. Here are my thoughts on motors. Few reasons I thought LM4 4.8 over LM7 5.3. The 4.8 uses flat top pistons, the lm7 uses dish. With the addition of 243 heads I would bump the CR into the 10 range. It would essentially be the same setup as the L33 without the stroke. No matter what motor I get the following will happen:
- 243 or 799 heads (if I don't get an L33)
- Trurion upgrade
- valve springs
- cam (timing chain, ooil pump ect)
- intake
- exhaust
- Ported TB
Hope you guys enjoyed. PLEASE feel free to give me feedback and thoughts, especially on motor setup. When it comes to picking one this is my priority list.
- Cost (budget, full time student, yeah I waited a long time to go back. Married.....no further explination needed)
- reliability (want it to run strong with a mild build without hickups)
- weight ratio (aiming for 50/50 distribution, if you know bmw's all the older ones used IL6 that were very heavy)
- power/torque (while this is the funnest part, after looking at what its going into, you'll realize its not going to take much to turn it into a death trap. further disclaimer: the car is getting a cage next month)
Thanks for looking!
Ironfreak
- die
- material
- machined bushing kit
- hardened shafts
- 8 ton ram
And.....I got the machine work done for free. So that give you an idea of the cost. To say building your own is cheaper, well its not. but they quality is what you put into it, and the features are way better then the standard bends that sell for that price.
I ended up with an LM7 5.3L iron block. Not exactly what I wanted but I can make it work. It was a stupid good deal. The guy was building it for his 1988 chevy truck, then the motor took a crap and he needed something running. I picked up:
- Full harness
- ECU
- block with new main, thrust and crank bearings
- two sets of heads
- two full intake setups (TB, rails, injectors ect.)
- all accesories
- oil pan and covers
All for a whopping $400.
Plans for the motor are:
- Quick hone while the block is apart
- find some flat top 4.8L pistons
- new oil pump, timing chain set
- LS6 hot cam
- LS7 lifters
- Rocker upgrade (possible new rockers, have a lead on some comp cams)
- push rods
- either 243 heads, or I have a set of 317 I'd mill down to the 243cc specs
- and either an ls1 or ls6 intake depending on the deals I can find.
Looking for a high CR motor this time around. I have some big injectors and a turbo I'd like to use but I might put together a different motor for that.
Thanks, that rotisserie worked out real slick! my buddies car is actually on it right now. for $100 in materials it was WELL worth the day it took to put it together and mount it. I couldn't imagine crawling around on the floor grinding that crap and stitch welding.
I understand budgets but with everything you will have into this wouldn't an aluminum 6:0 or even 6.2 L motor be a better choice? Much more upside than a 5.3 and would start with better heads and possibly more usable accesories than a truck motor.
once I can tune and tweak everything from the motor to the suspension I'll start phase two next fall. This will include but not limited too full M3 wide body kit, paint and larger tires. With the stock body and the new M3 suspension I can only fit about a 225 section width tire, and that's with a SERIOUS roll and pull on the fenders. besides straight slicks I'll have enough challenge keeping it straight at a weight of 2500lbs. (targeted)
Phase three will consist of the motor I want, possibly FI, and a conversion to a solid axle. As long as I'm on this earth over the next two years this should be the tentative plan.
I also got about 90% of the bender finished, unfortunately some of the very large holes I had to have drilled for me were wrong not allowing me to install the bushings. I'll get this fixed next weekend.
I also am about done with the chassis work in the engine bay, I have to get a different radiator to fit the LS motor then I can finish the core support quick disconnect.
I'll throw up some pictures later on.
Works good, heres a little video. Pardon the view, didn't realize I needed to flip the phone.
I also finished up the engine bay area for the most part, need to modify the shock towers a bit but I can do that later. We measured up the car and I will be ordering pipe to do 2 full cages in the e30s and possible a rollbar in a new 135is.
Video and updates to come soon.
