Sonoma ls1 speedo issue
Old Aug 11, 2013 | 12:50 PM
kpennepacker's Avatar
Default Sonoma ls1 speedo issue
Posted in pcm tuning but no hits so ill try here. I did my sonoma swap using an fbody harness and computer and an f body ls1 4l60e. I have an 8.8 with 4:30 gears. My buddy tuned my truck and changed tire size and gear ratio but speedo is off both on hptuners gauge pull down and my speedo. Both match but are off by about 30 mph. 40ppr vss and everything seems good in program. Any ideas is it the sonoma bcm
Old Aug 13, 2013 | 09:26 PM
rpturbo's Avatar
What year bro? If you can't find an answer here, try s10 forum. I know mine works fine in my 94.
Old Aug 14, 2013 | 02:54 AM
ls1nova71's Avatar
Sounds like your math may just be off. If HPTuners and your speedo are showing the same info, then when your tuner set the gear ratio and/or tire size, he was off a bit.
