Basics for a LS swap into a 1990 Chevy C1500?
Just wondering if someone could give me a list of the bare necessities on swapping a LS motor into my 1990 Chevy C1500. Any help would be greatly appreciated. Thanks
More info needed on your end. Using your stock 1990 trans?? etc...Swap plates (1" setback) OEM LSx truck FEAD, OEM ECM & harness. Easiest swap would be a complete dropout from a DBC motor. Try a SEARCH and buy a LS swap book.
We swapped a 2001 5.3 into 1989 Silverado with a 4L80e, used generic swap plates with the 305 mounts. Used some generic mid length headers for 2001 Silverado. Ran the factory 5.3 harness with the underhood fuse panel only 4 wires to hook up 12v to fuel, PCM, ignition.
![Name: 105br0x-Copy.jpg
Size: 34.1 KB](https://ls1tech.com/forums/attachments/conversions-swaps/608462d1501319136-basics-ls-swap-into-1990-chevy-c1500-105br0x-copy.jpg)
The following users liked this post:
Homer_Simpson (07-31-2022)
I want to do complete motor and trans swap. Prefer 5.3 6.0 or 6.2 Just need to find out mounts and what I need to use from the harness and if any pins to pull as well as fuel supply keeping my stock tank. Would a 98 fuel pump feed enough fuel or would I need a different one? The motor in there now is a 1976 Corvette 350 carbureted with the 700r4 trans. Just want to have something to build more powr and still get reasonable fuel mileage.
I did the LS1/4L60E in my truck and I love it. Here is a good website, lots of good info here, http://www.lt1swap.com/ . It is really an easy swap when you are done, but when you start it seems like you will never finish.
I did the 6.0 swap in my 94 silverado all my gauges work fine I used a 4l80e .stock gas tank with 98 silverado fuel pump ac delco direct fit.shoenfield swap headers direct fit.trans adapt motor plates from jegs $65.00 and a custom wiring harness from current performance.wiring harness is pricey but it plugged into my fire wall just like oe my check engine light work as if I had the oe motor.
The following 2 users liked this post by sbf:
Homer_Simpson (08-18-2022), Noggi (08-05-2023)
Thread resurrection here, sorry.
Does using the speed sensor on the 4L60e work the 89 speedo properly? I traded for a truck that has already had the 5.3/4L60e put in it. But the harness work and finishing re-assembly is on me to accomplish. Any suggestions? I would like to retain original gauges and speedo if possible.
http://www.tbichips.com/drac/
A 95 cluster won't fit a 88-94 dash truck without swapping out entire dashboard. The 95 and newer were nicer dashes. I previously owned a 94 that didn't have the tach...I bought a gauge cluster with tach from eBay and it worked without any issues. As far as figuring out which wires go to where..id buy a chilton or Hayes book for the electrical info. You will need to put specific wires from the LSx pcm to the new cluster.
Guys, my bad on the years....It's been a while since I've done this. The nicer 92-94 gauges with tachometer will physically fit an older C/K truck (88-91). The wiring is color coded and needs to be changed to fit the newer style gauge cluster. It is not as difficult as you would think and this change as been done many times on the truck forums. I did it on my 90 truck but do not have documentation. Here are a few links. Dakota digital is also an option
http://www.fullsizechevy.com/forum/g...ster-swap.html
http://www.dakotadigital.com/index.c...160/prd160.htm
http://www.chevytalk.org/fusionbb/sh...php?tid/258562
what do you mean by original sending unit? I have a 91 k1500 that im putting a 2001 5.3 in and am using the wiring harness and the ecm off the truck I got the 5.3 out of and want to know if my gauges will still work with that will I have too splice my old wires into the new wiring harness for the 5.3
so when you did the 6.0 swap did you use a ecm out of a truck with a 6.0 or did you use the ecm that was originally in your truck?
You will use the 6.0 harness but you have to convert it to stand alone. Or buy a stand alone harness already converted.
Don't forget to have the Ecu programmed to turn off the VATS so you can start it and run it. If you have done a lot of engine mods, you will need to find someone to tune it for you to get the most out of your combo.
