T56 shifter position in a C3
Old May 2, 2004 | 02:29 AM
tomj1404's Avatar
Default T56 shifter position in a C3
I was reading an article in Vette magazine about putting a T56 in a C3 and it said that their transmission was modified by Keisler to provide correct shifter position. Did any of you have any trouble with shifter position? I'm not going to buy my transmission from Keisler, so is shifter position a major issue I'll have to deal with?
Old May 2, 2004 | 03:59 AM
TTShark's Avatar
You didn't mention your engine.
Mine (LS1+T56) is about in it's original position.
Old May 2, 2004 | 08:28 AM
Budman78's Avatar
Launchin It!
It comes up about 1" back and 1 1/2" over to the passenger side. I just left it there and built a new custom leather boot. Most of the T-56 guys are making brackets to relocate the shifter handle.
Old May 2, 2004 | 11:26 AM
tomj1404's Avatar
Default engine
I am planning on going with an LS1 as well
Old May 2, 2004 | 12:04 PM
Scooter70's Avatar
It depends on which motor mount brackets you use. Buddy used a copy of the S&P ones, I have a modified version that pushed the motor forward a little bit. I'm going to machine a space block to go at the base of the shifter handle to space it over 1 7/8" and back ~3/4" to come up right thru the stock console.
Others have just welded a spacer on to the stock LS1 shifter.
Old May 2, 2004 | 02:24 PM
tomj1404's Avatar
I think I'm just going to go with the S&P mounts
Old May 2, 2004 | 03:25 PM
Budman78's Avatar
Launchin It!
Also the aftermarket shifters have taller towers. The might come into play also.
Old May 2, 2004 | 06:36 PM
tomj1404's Avatar
So are you saying that the shifter comes up a little further back and about in the middle of the console? Do you have anything on the side of the shifter like a shift pattern or is the whole area just covered with a boot?
Old May 2, 2004 | 06:41 PM
Budman78's Avatar
Launchin It!
The whole area is covered with a boot. Email me and I will send you a pic. budman-78@comcast.net
Old May 3, 2004 | 04:50 PM
70 LS1's Avatar
Conversion master
I did what Scooter did and moved the engine forward slightly. The shifter was then lined up front to rear with the opening in the console, but still came up through the middle. I then cut the top off the stock T56 shifter right below the flat spot then welded a spacer between the T56 shifter and the stock 4 speed handle. Everything fits under the console and the shifter uses the stock boot. If you don't move the engine forward, you can still use this design, just adjust the spacer until the handle comes up where you want it to.
