s10 money pit
today i purchased a few things that seem to add up quite fast! doesnt seem like alot but here is the list....
B&M trans cooler with temp switch and electric fan. black -6an fittings for both cooler and transmission bellhousing, 2 90 deg black -6an fittings, 2 -6an black straight fittings 6 ft of -6an black braided line
2 moroso catch cans w/ -12an fittings and drain, 2 -12an weld in bungs for valve covers, 2 90 deg -12an black fittings, 2 straight -12an black fittings, and 6 ft of -12an black braided line
Keep up the progress, even if it is just a part or two a week to keep it alive. Which I figure will come to a screeching halt once that baby arrives..
Congrats DAD, and keep up the good work. On the truck not the baby.. The Baby is all MOMMA now..
And also, better late than never, I hope you and your wife the best of luck with the baby and congratulations!!!
and for altering the frame, yes i did all the work myself, i welded in x bracing befor i hacked out the front crossmember, plated both sides then added the tube across it, then cut out my bracing, i then cut off the rails, capped them and added the moly hoop to the front,
i also made a tubular trans crossmember, and cut out all the rear crossmembers and put moly tube in the rear also, and ran some triangulated bars to under the cab to strengthen it, there are no factory crossmembers to be found on it lol
with the bushing style motor mounts, the edelbrock pro flo intake WILL clear a stock hood! yes mine is a cowel hood, but none of the bracing is cut and i still have around 3/4 of a inch before it touches, and with those motor mounts it wont move that far lol
i should be changing hoods in the future so i can switch the intake to the holley high ram intake, i love the look much more! lol but thats going to be after i get it running and driving again
feed for turbos might be -4an but ill prolly buy then premade, we will see what lengths i will need, the turbo returns are -10an and the catch cans are -12an
id keep going on ordering stuff but this week is the first week at daycare and we all know how expensive that gets!!!
scroll down to where you see the conversion mounts, select the option polyurethane for $130 and that's what I have
