'73 Stingray Conversion List Estimate (LSx+auto to manual)
LM7 1999 & Older Pullout: $600-1000
-or-
LQ4/9 '01 or older Pullout: $1200-1400 (crank flange is too long in '00 and older)
Batwing Oil-pan: $200
Oilpan pickup: $50
Windage Tray: $25
Dipstick/Tube: $10
LS1 intake: $100
LS1 fuel rail: $100
LS1 Injectors: $75
Gas Tank: $100-250
Fuel Pump: $75-110
Fuel filter: $25
Battery: $125
Exhaust manifold: $100
Dual Fans: $100
Pulleys: $50(?)
Radiator and hoses: $45-100
Elec. Headlight actuator: $100
Windshield motor Not vacuum (?)
Engine Total:
LM7$1880-2520
LQ4/9 $2480-2920
All trucks beginning in '03 are DBW (+$50-100)
Rebuilt T56-LS1 (1998 or newer): $2200 (incl $500 core)
Trans Yoke: $60
Shorten Driveshaft: $100
Master Cylinder: $150
Brake/Clutch pedal assembly: $75
Throwout bearing: $150
Reverse light connector: $15
Reverse lockout connector: $15
Vehicle speed sensor connector: $15
Bellhousing: $230
Shifter: NA
Flywheel/Pressure Plate/Clutch Disc/
Slave Cylinder w Release Bearing/
Pilot Bearing - Package Bundle: $386
T56 Total: $3396
Rebuilt T5: $1030 (incl $500 core)
Trans Yoke: $60
Brake/Clutch pedal assembly: $125
Bellhousing "621": $180
Shifter: $100
Tail housing and top plate/Shifter block/Shifter rail/Forks:$130
T5 Total: $2556
Rebuilt TKO 500: $2200
Trans Yoke: $79
Master Cylinder: $100
Brake/Clutch pedal assembly: $142
Throwout bearing: $70
Shifter: $100
T5 Total: $3416
