Ls1 camaro radiator trans cooler fitting size?
Old 09-27-2013, 02:12 AM
DCx
DCx's Avatar
Default Ls1 camaro radiator trans cooler fitting size?
I have a set of ls1 fans and plan to swap in a factory replacement ls1 camaro radiator in my mustang. I will need to fab up lines since I'm running a th400. What size fitting screw directly into the radiator for the trans cooler? I want to use AN fittings.
Old 09-27-2013, 09:53 AM
bczee's Avatar
IIRC I used a 3/8" NPT to AN -6 for my Trans line into the Radiator.
BC
Old 09-27-2013, 03:12 PM
DCx
DCx's Avatar
BC
Thank you very much. I will test some 3/8 inverted flare to -6 fitting when the time comes.
Quick Reply: Ls1 camaro radiator trans cooler fitting size?
