Do I have a complete 4l80e (am I missing anything)?
Old Oct 1, 2013 | 06:28 PM
llorracs93s10's Avatar
Default Do I have a complete 4l80e (am I missing anything)?
Finally got around to move the trans around and remove the back portion that was wrapped and I wanted to make sure I have everything for the trans before we get ready for install. First, it's a 2wd one right? I hope so.....lol And I am not missing anything correct? I need no more hickups to get this thing ready for install, Winter is coming quickly, need to get on it fast!
Old Oct 1, 2013 | 06:59 PM
john 67's Avatar
dipstick tube ? coolant lines - stock or adaptors
Old Oct 1, 2013 | 07:32 PM
Dip stick tube I am still trying to search for the best solution.....I have it going in a Monte Carlo SS and I have the 1 inch set back plates. It came with no tube so I don't want to order a stock one if it won't fit.
Coolant lines I think I am going with stainless steel braided lines like my fuel lines.
Other than that, its good to go?
Old Oct 2, 2013 | 08:58 AM
john 67's Avatar
you might need these
http://compare.ebay.com/like/270694969338?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar
Old Oct 2, 2013 | 01:05 PM
spacemanspif's Avatar
Those are what I have, Justin, except mine are for -6AN lines/fittings. Haven't been able to find them again on a search while looking for parts you may need. You need a neutral safety switch (or whatever the box on the driver's side is). I have one but not sure if it has the same plugs as your harness does...we'll have to see if you can use it when I grab it from my pile at my parents' house this weekend.
Old Oct 2, 2013 | 01:22 PM
bczee's Avatar
For the adapter to AN on the trans. I used Russell 640520 for -6 (or 640530 for -8)...
Be aware that the threads are NPSM and require a sealing washer. If you use a NPT (Pipe), it will work, but if you over tighten, you rise cracking the case. Use the correct adapter..! (does happen)
BC
Old Oct 5, 2013 | 01:08 PM
BC
Thanks for the advice, I plan to run -6 so I will use the 640520 part number but as for the NPSM and NPT, I am a noobie so no idea what all that means at this point lol. And I think I will try and use the stock original dip stick and see if we can work something out and get it to fit right in there. If not, I am sure we can figure something out and get it in there. Unless someone is using 1 inch setback plates and a 4l80 and they can tell me which would work best!
Old Oct 5, 2013 | 03:49 PM
bczee's Avatar
The NPSM's threaded body of the adapter is Straight vs Taper threaded body (NPT).
NPT = National Pipe Tapered
NPS = is a straight thread without the usual taper.
NPSM = threads are straight and meant for a mechanical joint, but are not expected to seal via the thread.
Old Oct 7, 2013 | 01:21 PM
That part number will not work.
The 80s use an extra length of tube inside the case on the rear fitting. It dumps fluid from the cooler directly onto important internals (the planetary set, I think) and is one of the reasons why the 80 can take so much abuse. You need to the -6 version of the parts that john 67 listed above because they have the extra length built in to the 1 fitting already...as seen in the pic he attached.
