97 LT1 Formula to LQ4 Swap Begins
i received new custom wire harness this morning and the alternator. need to get lt1 radiator and hoses from autozone. i still need to order my exhaust from headers to catback. also get ls1 rack and pinion, but i will install the truck manifolds for testing purposes. just to get it running.
I should have this car rolling by this weekend or at the latest next weekend.
wish me luck.
wish me luck.
i just noticed that the wire harness has the 5 pin MAF and the LS1 is a 3 PIN.
The 5 pin includes the MAF and IAT pins.
Either i repin it to the 3 pin MAF and the 2 PIN for the AIT. I dont really want to go that route.
I would rather just get a 85MM MAF witch has the 5 PINs and i would need to get a tune.
I have done some research.
This is what i currently have
Color
Brown MIL Lamp Ground Wire No Idea
Black Speedometer Wire No Idea
White Techometer Wire C230 / Cavity D / white Wire
DK Green Fan 1 ground C100 / Cavity J / DK Green
DK Blue Fan 2 ground C100 / Cavity H / DK Blue
Orange Park Neutral Signal C230 / Cavity J / Orance/BlackWire
Purple Break Signal No Idea
Grey ECT Lead Optional(N/A)
Tan Oil Pressure Lead C220 Cavity B / Tan Wire
Red Ignition Feed No Idea
Hopefully its understandable to yall.
Please feel free to correct it o make changes. 97LT1 to LS1 swap. Got the info from here:
http://shbox.com/1/harness_connector_faces.htm
Color
#33
I'm currently in the middle of a 99 LS1 into a LT1 formula 97 formula right now.
You don't need to swap out your cluster when you get the computer programed you just have to change a parameter for the tach and then use a 98 coolant sensor.
You're going to have to get a LS1 K member and motor mounts, the a arms shocks, springs will all fit from the LT1. LS1 Steering rack and knuckle.
On the CAI you can use any LT1 CAI, or make an LS1 lid work...it works really easy with a WS6 hood I've read.
If your using an LS1 Auto then you will need to add an plate onto the crossmember of the LT1 xmember as the tranny sits further back, you can't use the LS1 auto xmember it doesn't fit the body. You can use the LT1 tranny the electronics and everything hook up from 97 but you need a conversion kit.
I'm going to send you a PM on some parts and stuff. Let me know if you have any questions I'd be happy to help there are some great resources on here.
#34
lol i just got a warning for the code of compliance on my property.
Damn, wheres the meaning of freedom. lol.
Anyhow. I just need to get the fuel pump working and this car will be golden.
I purchased an obd2 scan tool to see if im getting any PCM communication.
