Back to building my 1996 S10 LSX swap
Hey guys i'm back to working on my LS build in my 1996 Chevy S10. I need some help on the wiring part of it. I will be purchasing a PSI Conversion harness on Thursday but needed to know what you guys pulled out of the engine bay and what wires you guys left. Please anyone that can help me out with the info, I would be gratful since I have heard this year is a little bit of a pain. Thanks in advance.....
IF it was a 93 or earlier, I would be able to tell you some stuff.. But I will say that you should definitely keep the harness as much intact as possible. Some of the stuff will run through the factory ecm and some of it will run through the ecm for the engine.
check out the lt1swap.com website for more information.
Have you looked in to Current Performance Wiring, they actually make a custom harness for the S-10's so you don't have to figure out what to keep and what to remove, it just plugs in and runs.
