ls swap 70 camaro wiring problems
I have a SSP harness installed, everything is done on my swap into a 70 Camaro except the wiring. the harness has all the sensors needed etc but no relay or fuses connected to it so I bought a current performance wiring relay box. my problem is the relay box has a relay for bank one and two injector and coil my harness has 4 pink for injector and 2 orange coils none of the wires are not labebed so how do I know which are bank one or bank two. the other loose wires I can probably figure out
That is weird. Every harness I do I mark the wires or I use the current box. Also do the have the obd port wired up ??? What year is your pcm? What year harness? You will need to know that to pin the wires out correctly. WWW.LT1SWAP.COM look here. This guy is very cool. If you find out what you have I can walk you trough it.
